#21
Re: Jetway JNAF93-Q77 Build HD3 PCIX
Up and running with an HD4 and the Jetway. No negative issues to report.
Put in a fresh SSD for the C-drive, used the Win7 disc image restore method to copy all my files. Learned that some plug-ins that are authorized to a machine are actually tied to the motherboard, Waves and Melodyne. So I had to rebuild the old machine to grab those, didn't quite plan ahead enough. cheers all, dg
the Computer: MBP M2 Max the ProTools: PT Studio | MH UNL-8 | Grace m905 | Artist Control the Rest: Amps | UA OX | V72 | Shelford Channel | |
#22
Here is the latest update, I just swapped out the CPU for an Intel Core i7-3770K Ivy Bridge 3.5GHz. Again, no problems just had to do a few Windows updates.
#23
Recently got a Jetway JNAF93-Q77 motherboard with a 3.2 GHz Ivy Bridge i5-3470 and 8 GB of G.Skill Ripjaws X Series DDR3 1600. Using a Corsair CX600M 600W power supply in a Logisys CS4803BK 19" rack mount case and a older Gigabyte HD6770 silent video card I've had for a few years (never used until now). Win7 Professional 64 bit on a re-purposed Crucial M4 60 Gb SSD, two new Seagate Barracuda 1 Tb - 7200 RPM - 64 Mb cache drives for audio.
Spent all day today setting it up which was a bit of a pain. I'm running a HD2 Accel with PT 8.1.1 and 2 UAD1 cards, 192 Analog & 192 Digital. Proper signed drivers ended up being an issue with 8.1.1, took a while for me to find a resolution. All would have been easier if I used PT 10 and UAD2 cards, but I can't afford that right now. The Newegg specs stated up to DDR3-1333, but the but the manual stated that DDR3-1600 was supported. In the BIOS it had a selection for XMP profile which I enabled. CPU-Z is reporting that the memory is indeed running a DDR3-1600 (PC3 12800) speed with rated timings of 9-9-9-24. I loaded up "Legion HD" demo session and played with it for a while with no issues at all, even dropping the buffer down to 64 samples. Processor usage is set to 3 at 99%. PCI usage got up to 40% or so and other than most of the DSP being used I had no issues. Overall this system is very responsive and I am thoroughly impressed. Over the next month I'm going to add two 24" LED monitors to the system and set it up with my Panasonic/Ramsa DA7 console for monitoring. I'll have a better idea of how it's holding up by then, but I don't see any problems. Those of you who are using a more modern version of PT should have no issues at all.
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
#24
Just an update. Added another Accel card and 8 more GB of RAM. Running 8.1.1 under Win 7 Pro 64 bit and all is good, actually great! HUI mode on the DA7 is working well as is all I/O. I'm very well pleased with this system and amazed a HD3 system with software asset only cost me $800.
#25
Has anyone done any particular bios settings ?
Usually you should set the drive controller to AHCI and disable c States as pert the Avid optimisation and troubleshooting guide.
PT10HD5 PCIX in 64Bit Magma Chassis, 2x192io's + 2x96io's & Legacy io's Pro Control & Fader Pack UAD2 Quad, Octo & All Plugins Black Lion Audio Modified MOTU 24io and 2408MK3 x2 TC Powercore PCI MK2 x2 & Firewire Softube, Sonnox, Eventide, SSL, McDSP, Waves |
Bios settings for JETWAY JNAF92-Q67 Mobo | songwritersoul | Pro Tools TDM Systems (Win) | 2 | 08-20-2012 07:05 AM |
JetWay JNAF92-Q67 and i7 2600 | pie55 | Pro Tools TDM Systems (Win) | 4 | 08-08-2012 09:06 PM |
standard pcix core card with accel pcix | pie55 | Pro Tools TDM Systems (Win) | 1 | 02-08-2012 03:33 PM |
New Build Review! Based on Mano/Ame? and SPCR Fanless build | Calipoop | Windows | 4 | 11-16-2011 09:38 PM |
PCI - E JETWAY nVIDIA GEFORCE73 | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-06-2007 01:04 AM |
