Old 07-25-2013, 08:12 PM
Connor Connor is offline
Default Selecting Instrument Track Auto Rec Arms
Am I missing a preference thats changed in PT11? Or is this a bug?
Every time I select an instrument track, it auto record arms that track.
This is really annoying as I am not used to this workflow. Would like to be able to change it back to how PT10 works.
Im on Mac OSX 10.8.4 PT 11.01
Old 07-26-2013, 06:18 AM
luken26 luken26 is offline
Default Re: Selecting Instrument Track Auto Rec Arms
Is the MIDI keyboard you are using an M-Audio Axiom Pro using Hypercontrol? If so, this bug has been around for some time. It started for me after PT 10.2 if I recall correctly. PT 10 through 10.2 did not exhibit this problem (for me anyways). I am presently on PT 10.3.6.
There were 2 or 3 threads in the VI Forum regarding this problem. The only common denominator appeared to be that every user was using an Axiom Pro. I am not aware of this problem with any other brand keyboard controller.
If you are using an Axiom Pro, disconnecting the USB and using your MIDI connection will eliminate the problem. It also means you will not have Hypercontrol activated.
The bug has never been addressed either by Avid or M-Audio. It is disappointing to hear it's happening in PT 11 also. However, I was under the impression Hypercontrol would not be supported in PT 11.
Lou
Mac Pro (2019) with 3.5GHz 8-core Intel Xeon W Processor, 48 GB DDR4 Memory, 1TB SSD
Catalina 10.15.7
Avid Pro Tools Carbon, Eleven Rack (ERXP 2.0.1), Neve Shelford Channel, SSL Fusion Analog processor, Avid S1 Control Surface, Yamaha Montage 7 (also used as a MIDI controller), Korg Prologue 16 and Adam A7X Monitors.
Pro Tools Ultimate 2021.6, Logic Pro, VEP 7, Exponential Audio. Eventide, FabFilter. iZotope, McDSP, MDW, Softube, Sonnox, Soundtoys, Waves.
Turn off Auto Record Enable Clicked Instrument Track? DrFord macOS 16 04-04-2023 05:47 AM
BUG? selecting midi track arms record for selected track browniespeaks Windows 40 06-10-2013 11:41 AM
Selecting instrument or midi track automatically arms record tunes7 Pro Tools 10 4 05-03-2013 02:51 PM
selecting instrument track? play4theworld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-16-2011 04:59 PM
record track un-arms after stop! soundwavve Pro Tools TDM Systems (Mac) 3 07-30-2008 08:16 AM
