Old 04-15-2012, 05:00 PM
JoeM JoeM is offline
Default Need help with connecting Lexicon PCM 80 to HD Omni
Hi, I'm looking to connect my PCM 80 to the Omni to use as an external EFX processor. I've connected the Omni and PCM 80 by S/PDIF but am not clear on setting up the clocking. I think I need to set the PCM 80 to external clock and keep the Omni as the master clock - would that be correct? Also, I'm not sure what I need to do in setting up the I/O in the Omni's settings. Can anyone please advise or point me in the direction where I can find out more info on how to do this? I gave the PDF manual a quick look but maybe I'm missing where to find this info.
THanks for your help,
JoeM
Old 04-15-2012, 05:51 PM
nst7 nst7 is offline
Default Re: Need help with connecting Lexicon PCM 80 to HD Omni
Definitely set the Omni as the master clock if you can. Which means you just leave it on "internal" which is what it should normally be set at anyway. You'll just have to figure out how to set the Lexicon to be clocked externally.
In the Omni's main tab, make sure that digital is set to spidf rather than AES, and that adat is set to optical (so that makes sure spidf is not set to optical).
Once you do that, you should be okay. You may know this already, but you can just use the Lexicon as an insert, either on an audio track, or on an aux track (where you use an aux send from your audio track to that aux track).
It works just like a plugin. When you click on an insert, instead of inserting a plugin, you choose "output", and select spidf, and the Lexicon functions as a plugin.
Note that this will not work if you've selected Low Latency monitoring. But it should work fine if you're recording in the typical fashion with a low buffer setting.
Old 04-15-2012, 07:24 PM
Great! Thanks so much for your help and great explaination. I didn't know how to use the S/PDIF output when setting up an insert so this is a big help for me. Thanks again!
JoeM
Old 04-15-2012, 08:02 PM
I've set up everything as you pointed out and have the PCM 80 set to external clock and it's seeing the correct sample rate but when I open the project I'm working on I'm getting a Session Note window saying " The following plug-ins were made inactive because of insufficent system resources: Hardware insert (2). Looks like PT crashed as I tried to save the note details.
I'm going to try to reboot the Mac and everything . Can you advise about this note? thanks
JoeM
Old 04-15-2012, 08:40 PM
The note said: Track "Audio 1" Insert D ("Hardware insert") has been made Inactive because the associated DigiLink assignment is currently not available.
Track "PCM 80" Insert A ("Hardware insert") has been made Inactive because the associated DigiLink assignment is currently not available.
I went into Hardware setup and for input 5-6 I selected S/PDIF 1-2 and that took care of the "Track "PCM 80" Insert A ("Hardware insert")" message but I'm still getting the Track "Audio 1" Insert D ("Hardware insert") message - not sure what that is. I also set Output 5-6 to Optical (S/PDIF but I'm not sure if that's correct.
In any event I still do not see the S/PDIF I/O available as an insert or an input to an aux track. I'm only seeing the analog choices. Looks like I need to study the IO Setup Primer PDF to get a better handle on using the Omni.
JoeM
Lexicon Mx400 With Mbox 2 pro "NEED HELP" Connecting SV.P ROMO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-03-2008 05:20 AM
Connecting an Lexicon MPX200 through Digi001... homerg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-20-2006 09:23 AM
Connecting 192 IO to Lexicon 300L Haniel Trisna Pro Tools TDM Systems (Mac) 5 09-08-2003 09:11 AM
Connecting Lexicon MPX 1 via S/PDIF fmckinnon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-02-2002 12:36 AM
advice connecting Lexicon MXP1 with my 001... Vaphoron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-23-2001 12:58 AM
