Re: How to tune SPQ card in MTRX Studio
Sorry for a little bit out of topic question but I think still related to the MTRX studio.
Is it possible to EQ with it a passive bi-amped speakers such as JBL 3678? Does the MTRX can group two physical outputs, apply crossover to them and then EQ it as a single separate channel (e.g Left or Center or Right)? I am asking it as I had a negative experience in the past with Intonato software which couldn't do so. I currently use a QSC DCM10D for only crossover functionality. So I would like to be able to connect to my QSC DCA1644 amps directly from the MTRX. Also what hardware Monitor controller do you use? I would like to use my D-Command as PT controller and only ditch its monitor section for e.g MOM.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
I don't know much about EQing passive speakers or if you could group those in MTRX. I just explored very small part of testing some eq curves on my LCR.
SPQ is applying filters to it’s outputs and they are seen as mono. You could also bass manage speakers, but about crossovers I wouldn’t know. I don’t have separate hardware monitor controller (yet). In this thread http://duc.avid.com/showthread.php?p...64#post2573764 Jeff pointed me to creating solo and mute from fold downs. That is quite easy to do and you can also program those folddowns into Control app. Only downside to this option is that at the moment you can only use 8 fd’s in the app. I made some screenshots of that and there is link to tutorial on creating solos and mutes in DADman. I believe you can easily use your D-command for monitoring, I guess you can only go to 5.1 or 7.1, and probably go analog from MTRX to Dcommand and then to your amps. And thanx Michael for sharing your experiences about Intonato on gslutz, it helped me decide not to go with JBL and wait a bit for Mtrxstudio. I got excellent deal on it from a German shop Digitalaudioservice, (Christian). |
But if the MOM does all the tasks regarding soloing channels, muting and headphone sending level without requiring to use Eucon it would be a solution. ***Eucon cannot be used together with the Icon protocol but I hope that MOM can share Icon one. Welcome ;-) I think that MTRX Studio is a way-way more than Intonato (even if it worked) in every aspect and for the almost the same price.
You can definitely use REW it's just very time consuming to re-sweep for every adjustment to see the result. In Smaart you essentially have a live view of everything which is extremely helpful when tweaking speaker positions for optimisation. Always amazing to see how much influence even a computer monitor has when being moved around.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
First steps with MTRX Studio | SMM | Pro Tools | MTRX & MTRX Studio | 228 | 05-25-2022 07:38 AM |
MTRX Studio i/o | Cheesehead | Post - Surround - Video | 9 | 02-21-2021 08:17 AM |
MTRX Studio and MOM Awesomeness | DonRWatters | Pro Tools HDX & HD Native Systems (Win) | 5 | 12-07-2020 05:23 AM |
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card | antonis | Buy & Sell | 9 | 04-11-2020 06:47 AM |
MTRX Studio - No AES?! | Ryan Young | Pro Tools | MTRX & MTRX Studio | 23 | 02-23-2020 02:13 PM |
