Old 08-14-2018, 04:23 PM
DaveDoubtfire DaveDoubtfire is offline
Default Plugin Automation Suspend
Hi there!!
So basically I have a project in which I have to do some EQ work on each region.
I select the region, suspend, tweak the EQ and then Write to all Enable. So that for me works fine.
My question is: in order to tweak the EQ on that track, I need to be on the suspend mode. What if on track number two I have already tweaked another region that plays at the same time? My problem is that I can't hear the final result of my tweaked region on track number 2 whilst I tweak the region on track number one to get a similar sound. With suspend mode on I'm not listening to the other plugins' work.
Is there any way I could do this?
Thank you very much!
Old 08-14-2018, 05:01 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Plugin Automation Suspend
Preview automation
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 08-15-2018, 12:24 PM
michaelfbates michaelfbates is offline
Put the track you wish to tweak into touch, then turn on preview, tweak away then hit write to all enabled.
At least that's how I do it, there are probably many ways to skin this particular cat.
PT Ultimate 2021.3 | macOS 10.15.7 | Mac Pro 7,1
michaelfbates.com
imdb.com/name/nm4876413
Old 08-19-2018, 06:55 PM
reidj reidj is offline
I do this by using Preview Mode also. I always have my tracks in Touch/Latch so I just get the setting I want on the plug in and either Write To Selection or Write To End, whatever I need.
Now if Avid would let us have a Preview All Except Volume...
HTML code is On
'Suspend Automation' enabled, resets all my plugin settings! GuitarGiddz macOS 8 08-24-2020 07:54 AM
Suspend automation lindellsound Pro Tools 11 3 12-08-2015 04:47 PM
Suspend automation issue ianfleming1992 Pro Tools 11 5 02-08-2015 12:50 AM
Use of Suspend Automation ramu745 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-15-2009 08:18 AM
Suspend Automation Playback for some but not all Don Geppert Pro Tools TDM Systems (Mac) 3 02-16-2006 04:31 PM
