Old 03-01-2011, 12:24 AM
finkbmx finkbmx is offline
Default Eleven Rack Hardware Reamp negative latency AKA Early???
Hello, I have an Eleven Rack and Pro tools 9. I recently reamped the dry signal out of the outputs to amp, into an amp and cab, mic'd the output using 3 mics, 1 to the built in mic input, the others through focusrite pre's into the line inputs of the Eleven Rack. What is interesting is that the reamped signal is earlier than the dry signal, by at least 1300 samples. Does anyone know why this might be?
Thanks
Old 03-01-2011, 04:34 AM
adamqlw adamqlw is offline
Default Re: Eleven Rack Hardware Reamp negative latency AKA Early???
You were recording at FTL speed?
Not very helpful, I know.. sorry...
Can't ReAmp in Eleven Rack (output inactive) jlg75 Eleven Rack 4 02-07-2014 09:10 AM
eleven rack latency after updating to pro tools 10.3 oplatner Eleven Rack 0 11-04-2012 01:03 AM
Eleven Rack latency migu Eleven Rack 14 09-06-2012 06:34 PM
eleven rack reamp question anth Eleven Rack 2 02-24-2012 08:17 AM
How to reamp with eleven rack???? TeamContra Eleven Rack 3 09-07-2011 05:22 PM
