i need to know when i can download this upgrade
Now.
Administrator Avid Pro Audio Community |
its 12:30 in the morning ... are you going to bed? G4 733 Ti 1Ghz 001 Mbox LE6.4 OSX 10.3.8 QT 6.9 XP80 XV2020 Midiman 2 POD2 Logic 6.43 |
Everything installed ok and all general operations a go.....
Have you tried using the midi trimmer tool in larger sessions? Is there a 2 second latency still?
This is what I want to know!!!
International Award Winning Arabic Fusion www.ajmusiconline.com --------------- 2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8 3xVisionDaw,NI Komplete,Yamaha 01V/96 |
whats different in this version?
If you use a lot of midi, there are some well documented bugs.
Digi said they would be fixing these in this update.
Digi, did you fix the unexpected quits in this update???
Quits when changing HW buffer on a larger session, closing a session or quiting PT on larger sessions sometimes, and quits when previewing an audiosuite plugin during larger sessions. Also, infrequent kernel panics only in Pro Tools. They seem to be random but only occur in Pro Tools. Is this release approved for the 001??
Chris- Digi001 6.4, 10.3.3, Reason 2.5, Waves Diamond v4, Yamaha 01V96, Dual 1.25 w/FW800 - 1GB, 2x120GB |
![]() Quote:
It is not technically approved for 001, but I (and many others) are using it with no problems.
Mdi note trimming GOOD!
dk
www.dpksound.com |
