Old 03-14-2004, 11:09 AM
randykc randykc is offline
Default MIDI setup for 6.1 in OS X?
Please help!
I've updated from 5.1 in OS 9 to 6.1 in OS X and cant seem to figure out how to set up the midi. I know 6.1 runs on AMS, but how is it set up? I did the picture map with cable routes and all of that in protools midi config, but I'm positive there is more. Also I have factory names from sound modules that need to be loaded but those are in OMS format.
Can anyone help?
Thanks in advance
Randy
Old 03-14-2004, 06:21 PM
Twinstream Twinstream is offline
Default Re: MIDI setup for 6.1 in OS X?
might try this....
http://www.savagetranscendental.com/cherrypicker/
its 12:30 in the morning ...
are you going to bed?
G4 733 Ti 1Ghz 001 Mbox LE6.4 OSX 10.3.8 QT 6.9 XP80 XV2020 Midiman 2 POD2 Logic 6.43
Old 11-28-2005, 12:50 PM
Thanks!
is this any different for the digi 001? Sorry I should have specified that.
Also, while I have you. Does digi plan to do any more protools versions for the digi 001? I would love to run protools 7, but its not compatible
Multiple MBox Pro Instances/Icons in Audio MIDI Setup -> MIDI Studio lpeckham macOS 8 04-24-2014 07:39 AM
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 01:02 PM
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 03:44 PM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 01:06 AM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 01:24 PM
