I'm trying to add my Yamaha DTXpress electric drum kit in Audio Midi Setup. However, under the Yamaha pull down menu, the DTX series of modules is not listed. Has anybody else succesfully added this drum module? How did you do it?
I'm running a Dual 1.25 G4 w/ 1Gb RAM. Pro Tools 6.1 on OS 10.2.7 with a 002R Thanks Kyle
I've seen a million faces, and I've rocked them all. |
Add a new device and name it accordingly. Set midi channels send and receive. Set correct device id number. Search the internet for either a midnam file for your Yamaha or a OMS list of patch names. Search for cherrypicker which will convert OMS names to a midnam file. Place midnam file in correct folder and try it....
its 12:30 in the morning ... are you going to bed? G4 733 Ti 1Ghz 001 Mbox LE6.4 OSX 10.3.8 QT 6.9 XP80 XV2020 Midiman 2 POD2 Logic 6.43 |
Audio MIDI setup says DIGI 002 midi device is offline | oliarnalds | MIDI | 17 | 10-23-2016 11:13 PM |
MIDI Setup - Not seeing USB Audio Device as an Input Port Option | oldtracy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-15-2013 10:22 PM |
Unable to locate m-audio device | ohio | Pro Tools SE and Essential (Win) | 5 | 01-10-2012 12:28 AM |
Unable to locate M-Audio Device (Win. XP) | lawdaproducer | Pro Tools M-Powered (Win) | 0 | 09-15-2009 09:10 AM |
USB MIDI device connection - Mac Audio MIDI Setup | jongilbertson | MIDI | 2 | 06-11-2008 11:13 PM |
