Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 09-02-2010, 10:21 AM
Limelight Limelight is offline
Default 2 SC48 Questions
Hey guys. Two quick questions that I want to make sure I know how to do before our SC48 arrives. I mix a large corporate band and currently use 2 different delays; one for slower effect type delay on vocals and a fast slap-like delay for horn solo's etc. How can I achieve setting up taps for 2 seperate delay units? Can I do this by using the function keys? I assume also that I could save them as snapshots with 2 different pre-defined tempos and then recall those correct? Second Question: how do I achieve assigning a graphic EQ to an input channel? I know it might seem overkill, but on the Yamaha digital consoles I have been using, I am able to insert a GEQ to a channel like Kick or a vocal channel for detailed eq'ing. Any way of doing this on the VENUE?
Thanks, I look forward to your responses.
Chris
Old 09-02-2010, 11:01 AM
sonicboost sonicboost is offline
Default Re: 2 SC48 Questions
I use 1 universal tap tempo, but set the parameters of the 2 delays differently, 1 based on quarter notes, the other based on 16ths, or 32nds, or dotted, or, or...
This way, I'm only tapping in one tempo from song to song, but the delays still behave differently, but still relative to the pitch.
CONFIDENT IN CHRIST,
Eric Myers
Old 09-02-2010, 11:10 AM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
There is probably another way to do this, but you can either go into each plugin and tap or set your tempo there OR you can have one reading the system tempo and manually configure the other. Yes, the delays work well with snapshots.
I will get back with you on the GEQ. I will mess around with my desk tonight, unless someone else pipes in. I know fluidly how to do it on Outputs, but an input...haven't done that before.
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 09-02-2010, 01:57 PM
Brent Lind Brent Lind is offline
I also wanted to use a GEQ on an input channel but it cannot be done on Venue. I opted for the Serato Rane Graphic EQ plugin and have very much enjoyed it.
Or you could route a single channel (primary vocal) through an aux and put the graph there, if you have an aux to burn.
Old 09-03-2010, 08:40 AM
Great idea, seems too simple to not have already been doing. Thanks! And yes, that was my next question: if you cannot assign a GEQ to an input, are there any good GEQ plugins out there to insert on a channel? Thanks again for the helpful replies.
Old 09-09-2010, 07:15 PM
rivetheadsound rivetheadsound is offline
i use the rane eq all the time. rarely use the onboard graphics. i love it. super dsp friendly too! plus it comes with the PEQ!
Brian Lloyd
FOH Engineer - In The Mood LIVE
-Reality.exe corrupt. Reboot?-
Venue SC48
Macbook 13"
HP 2525TX Tablet
Motion Tablet LE1600
Mac Mini 2.6 dual core with 1TB 4gig Ram
SC48 Basic questions [email protected] VENUE Live Sound Systems 1 05-21-2011 06:53 PM
Couple of additional SC48 Questions! Limelight VENUE Live Sound Systems 1 09-24-2010 11:03 PM
SC48/LE firewire rookie questions Jonathan K VENUE Live Sound Systems 7 04-04-2010 04:59 AM
Some questions on SC48 and Protools ionStorm VENUE Live Sound Systems 4 02-03-2010 09:16 AM
SC48, some questions, some answers ? Nicolas Haber VENUE Live Sound Systems 3 12-06-2009 01:45 PM
