R6016 - not enough space for thread data
Hello.
I'm running W7 Ultimate 64bit and PT.9.0.3 on Gigabyte GA-EX58-UD3R self built pc (based on the I7 thread). (Se my profile for full details) I sporadically keep getting an R6016 error message when I either try to use Audio Suite or insert RTAS plugins. It happens to all sessions after some use. The message is : R6016 - not enough space for thread data It crashes PT so I have to restart W7. |
Re: R6016 - not enough space for thread data
I will post a full Sandra report later to day after work.
Any thoughts what the cause could be ?
I have checked that all my plugins are supported and up to date! There is a similar thread about this issue here : http://duc.avid.com/showthread.php?p...98#post1826598 |
SiSoftware Sandra
Computer Model : GigaByte EX58-UD3R Workgroup : TEXAS Host Name : t10 User : Christian Dillner Hagen Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : GigaByte EX58-UD3R BIOS : Award (OEM) Fj8 08/02/2010 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : OCZ OCZ3P1333LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (7-7-7-20 4-27-8-4) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (7-7-7-20 4-27-8-4) Memory Module : OCZ OCZ3P1333LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : ATI FireGL V3600 (120 SM4.0 600MHz, 256MB DDR2 1GHz 128-bit, PCIe 1.00 x16) Graphics Processor STREAM GP Processor : ATI FireGL V3600 (120SP 600MHz) Storage Devices WDC WD5002AALX-00J37A0 (500.1GB, SATA600, 3.5", 7200rpm, 32MB Cache) : 466GB (F:) WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D:) (E:) CORSAIR CMFSSD-128GBG2D (128GB, SATA300, SSD) : 119GB (C:) Optiarc DVD RW AD-7200S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices sessions (F:) : 466GB (NTFS) @ WDC WD5002AALX-00J37A0 (500.1GB, SATA600, 3.5", 7200rpm, 32MB Cache) vi (D:) : 443GB (NTFS) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) xp (C:) : 119GB (NTFS) @ CORSAIR CMFSSD-128GBG2D (128GB, SATA300, SSD) data (E:) : 488GB (NTFS) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) Optical Drive (G:) : N/A @ Optiarc DVD RW AD-7200S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : ATI (AMD) HD Audio Codec Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Brother HL-1430 (600x600, USB) Printer : Brother HL-1430 (600x600) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.1 |
Could it be you running different kinds of RAM? have u tried using only the corsair 4GB sticks.
PC 7980XE @ 4.2 PT 12.7 Ableton 10.0.1 Great River ME-1NV, Ehrlund EHR-M, Axiom Pro 49, Brauner Valvet, Oktavamod MXL-910, RODE NT5 with Oktavamod MJE-384K, Crane Song Trakker, SSL 611EQ, SSL X-Desk, Sennheiser HD600/650 IS Pro Double 6" Speakers, www.intelligentsound.se/ |
Yes i am.
I will check if running only corsair will make any difference tomorrow. Thanks for the tip. |
Tried removing the OCZ ram, but still get the r6016 error!
All my sessions are at 96kHz 24 bit.
After further investigation it seems only to happen to third party Audio Suite or RTAS plugins. But I have checked that all my plugins are up to date!
A Google search for that error seems to point to a Microsoft C++ redistributable problem.
Can you try downloading and installing the latest C++ redistributable and let us know if that helps? https://www.microsoft.com/download/e....aspx?id=14632 |
Microsoft Visual C++ Runtime Library Runtim Error R6016 | 100595 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 08-14-2014 08:11 PM |
segmentation fault in thread "main thread",at address 0x0 when import session data | cheney5 | Post - Surround - Video | 2 | 05-24-2012 04:00 AM |
C++ Runtime Error R6016 ! | daysix | Pro Tools M-Powered (Win) | 13 | 04-04-2012 06:23 PM |
bus error in thread main thread at address 0xbfffd010 | abayman65 | Post - Surround - Video | 2 | 01-28-2010 07:17 AM |
Hey, where is todays..'Everyones sick of the XP issue,heres another thread' thread? | greenroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-10-2002 11:59 AM |
