Old 01-06-2014, 01:52 PM
nst7 nst7 is offline
Default New Waves WLM Plus Loudness Meter
Waves has updated their loudness meter with new features, called WLM Plus. I have not watched the video, and don't know what new features were added. But I thought it might be of interest.
Note that any WLM owners covered by WUP will get this update free.
http://www.waves.com/plugins/wlm-lou..._campaign=wlm#
Old 01-06-2014, 01:55 PM
Pete Gates Pete Gates is offline
Default Re: New Waves WLM Plus Loudness Meter
Peak limiter is the main one I've noticed. Though for me, having upgraded an HD3 to an HDX2, it just exacerbates the issue that Waves isn't AAX DSP
Pete
Old 01-06-2014, 03:17 PM
8dB.co.uk 8dB.co.uk is offline
They've basically updated the feature set to be like the Dolby Media Meter 2. I avoid using DMM realtime because it adds latency even if it's not processing. I tend to put metering plugins on taps off of the main feed rather than across it for this reason.
The Waves L3LL has minimal latency native but the new Avid Pro Limiter is a good match, and is a true peak limiter.
Sent from my iPhone killer
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Old 01-12-2014, 01:40 AM
gugu gugu is offline
I agree, but when you're not on a HDX rig it's a big CPU eater.
IMHO, it would be fine to have also a lighter version without the metering features.
gugu
Old 01-12-2014, 01:42 AM
I'm not on a HDX rig. It's taking next to no power. Seems very efficient. I have never managed to get the PT11HD usage any higher than 40%, even with a big 200+ voice project with lots of realtime processing.
Old 01-12-2014, 04:00 AM
tamasdragon tamasdragon is offline
gugu
CPU eater? I use Avid's ProLimiter on all of my setups and it runs without a big tax on CPU even on a i5 laptop. Built-in loudness meter, a very good true peak limiter and in the audiosuite version there's a offline loudness analyser too.
my blog:Tamas Dragon
Old 01-13-2014, 02:03 PM
seanmccoy seanmccoy is offline
I upgraded to the WLM Plus (HD Native), and in addition to the added peak limiter, which I likely won't use, they also added a number of current and updated presets to what had been a pretty paltry list. Helpful in keeping up with the ever-changing standards. No noticeable change in CPU drain.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 01-13-2014, 04:38 PM
Brandonx1 Brandonx1 is offline
Big big plus one. I don't even understand the other offerings. Pro limiter is everything you need and sounds fantastic with very little CPU usage.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 01-14-2014, 08:30 AM
Here is what I get on a MacPro Nehlem octo core 2009 24Go Ram PTHD 10.3.8 MacOS X.8.5.
A rather light surround film session without ProLimiter:
http://duc.avid.com/images/attach/png.gif
The same session with only two 5.1 instances of Pro Limiter:
I don't call this very light CPU load.
gugu
Old 01-14-2014, 08:58 AM
Are saying only 2 instances of pro limiter takes you to 20ish% CPU usage? You need a faster computer! I probably run 15 instances of pro limiter along with 40 cedar DNS one, 5 5.1 revibe's along with 100 other plug ins and hit 30% CPU. Not sure why are are having such bad performance.
I was comparing pro limiter to the alternatives. Dolby media meter is a total dog, all the other tp limiters have much worse performance in my experience
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
HTML code is On
Waves Loudness Meter Audiosuite The golfer Post - Surround - Video 10 03-09-2013 09:03 AM
Waves WLM Loudness Meter - what do you use? dream5695 Pro Tools 9 22 07-21-2012 08:45 AM
Waves Loudness Meter now added to a couple bundles nst7 Post - Surround - Video 0 02-02-2012 09:47 AM
New Waves Loudness Meter for Post nst7 Post - Surround - Video 27 01-17-2012 06:49 PM
New loudness meter TC LM5 nucelar Post - Surround - Video 6 01-24-2008 02:50 AM
