Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 04-22-2011, 07:24 AM
justus1900 justus1900 is offline
Default Best Way to Transfer PT Files Between HD
I just bought a new 750GB/7200RPM/64MB Cache Hard Drive from Newegg. I need to know the best way to Transfer all of my Session Folder Files from my 250GB/7200RPM/8MB Cache Hard Drive with out losing any of the Audio Files or any of the other files in the Folder Transfer. I heard you can't just do a Copy/Paste from one Hard Drive To The Other Hard Drive. Any help would be appreciated, Thank you
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 04-22-2011, 09:07 AM
Default Re: Best Way to Transfer PT Files Between HD
Hmm. Well I have done a Copy/Paste before and all of the Wav. Audio files didnt transfer? Also I have read other people say the same thing, I remember reading some place you need to Load the Session Folder and do a Copy File/Folder or something to make everything transfer to the new Hard Drive but IM not for sure so IM asking, Thank you
Main:
JBL LSR4328P 8"
Old 04-22-2011, 05:06 PM
Top Jimmy's Avatar
Doing a complete drive copy/paste should introduce no problems.
Where problems do arise is when you copy just a session folder that does not have all of the media files used in that session located within that folder. If you suffer from this problem, saving the sessions within Pro Tools using the "Save Session Copy" command will bring together all used media within the one session folder.
James Cadwallader
Old 04-22-2011, 07:32 PM
Craig F Craig F is offline
after the copy:
open Pro Tools
set the old drive to Transfer in the Workspace
open each session on the new drive (make sure the new drive is set to Record in the Workspace)
if something is left on the old drive it will get moved to the new one
Thank you,
Craig
Old 04-28-2011, 05:32 AM
I did a complete drive copy/paste and it introduce no problems at all. Seems all of the Session Folders and Files transfered with no problems.
Main:
JBL LSR4328P 8"
Old 04-28-2011, 08:37 AM
DigiTechSupt's Avatar
Just to be clear - a 'copy/paste' or 'drag and drop' from one drive to another is typically not recommended unless you know for sure that all the audio for your sessions are contained in the audio files folder AND you understand that you have to relink the media or set the previous drive to 'T' so that the media is not accessed on that drive when opening a session.
When you drag/drop or copy/paste the session file still has info in it indicating that the audio files for a session are on the original drive and it will access that drive unless you update the links to your media on the new drive or set the original drive to 'T' in the Workspace window so that Pro Tools will look to the new drive for the media.
A better option is to open each session and do a 'Save Copy In' and choose to copy all media - that way the session file is updated with the new location of your media and it gathers all media for the session in the new location, regardless of where it was located previously.
Avid Audio Tech Support
Support FAQ
Old 05-02-2011, 11:08 AM
aka21stCentury aka21stCentury is offline
I would always choose save as: mac/pc compatibility and transfer the files from the opened and correct Pro Tools session as Tech Support suggested and others... making certain the fade folder is also duplicated.
Now what about NTSF 3g from a PC to Mac. Anyone care to comment? Can Pro Tools write on a Mac running Snow Leo to an NTSF external disk if fast (non-caching) option is used with NTSF 3g?
Also can a PC created session be played back on a Macintosh 10.5 or higher with NTSF 3g without glitching? Anyone know? 24/44.1k - 88.2k
Old 05-02-2011, 01:18 PM
sunburst79 sunburst79 is offline
No
Yes.
A far better solution is to install HFS+ support on the PC and then format the external or transfer drive as HFS+. Theres also MAC-NTFS from Paragon Software. That will let you write to a NTFS volume from OSX.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Transfer files from pc to mac os 9 ZipSnipe General Discussion 3 12-18-2013 04:23 AM
How do I transfer session files mac to mac busk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-06-2012 12:24 PM
Transfer .dmg files! baddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-29-2009 09:52 PM
How to transfer files across the net? PDEES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-08-2003 06:12 PM
Help, how do i transfer pt files from mac to pc! iguitaryo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-19-2003 11:52 AM
