PT8 not starting - stuck at DAE Loaded
Ok - first I purchased the upgrade to PT8 and that wouldn't work because of my outdated AMD processor - something about SSE instructions. But I guess I understood it was old and I should probably get with the times. So I upgraded my computer system including my OS - to Vista 64-bit. Now I'm hearing I can't run PT8 because of that!
**There has to be some solution - PLEASE HELP!!!!** Every time I try to start the PT icon it hangs at "DAE Loaded". Digi002 AMD Phenom X4 8GB Ram Vista Ultimate 64-bit |
Re: PT8 not starting - stuck at DAE Loaded
First, why did you get a Phenom? The Intel processors are running rings around them in terms of Pro Tools performance.
Next, why on earth did you get Vista? While Vista 32 Business and Ultimate are qualified with Pro Tools, there are not a lot of Pro Tools users who would recommend anything but XP. Also, have you installed IE8 on this new system? Last, we know next to nothing about this new system of yours because you have not posted detailed specifics about it. It's possible that there may be OTHER hardware incompatibilities, but noone here would be able to tell you about it until we know the details. My intention is not to put you down or anything, but after the incompatibility issue you had in the first place, it really makes no sense to me that you didn't do further research when spending money (actually, wasting money) on your new system.
spk - I do feel worse than I did before - but I actually do appreciate your honesty and reply. I am more of a "weekend warrior" when it comes to ProTools - but you are correct in that I did NOT do my due diligence.
I am running IE8 and these are my sandra specs - thanks again for any input. SiSoftware Sandra System Host Name : PROTOOLS User : Workgroup : WORKGROUP Processor Model : AMD Phenom(tm) 9500 Quad-Core Processor Speed : 2.20GHz Model Number : 6600 Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Internal Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, 64 byte line size L3 On-board Cache : 2MB, ECC, Synchronous, Write-Back, 32-way, 64 byte line size, 4 threads sharing System System : To Be Filled By O.E.M. To Be Filled By O.E.M. Mainboard : XFX MB-N78S-8209 Bus(es) : ISA PCI PCIe USB FireWire/1394 Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : No System BIOS : American Megatrends Inc. 8.15 Total Memory : 8.00GB DDR2 Chipset 1 Model : AMD (Family 10h) Athlon64/Opteron/Sempron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1.8GHz (3.60GHz) Total Memory : 8GB DDR2 Memory Bus Speed : 2x 400MHz (800MHz) Video System Monitor/Panel : Generic Non-PnP Monitor Monitor/Panel : Generic PnP Monitor Adapter : NVIDIA GeForce 9600 GSO Physical Storage Devices ST3500410AS 500GB (SATA300, NCQ, 16MB Cache) : 465.76GB (C:) ST3500630AS 500GB (SATA150, NCQ, 16MB Cache) : 465.76GB (D:) ATAPI iHAS324 A (SATA150, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 465.76GB (426.93GB, 92% Free Space) (NTFS) @ ST3500410AS 500GB (SATA300, NCQ, 16MB Cache) New Volume (D:) : 465.76GB (431.86GB, 93% Free Space) (NTFS) @ ST3500630AS 500GB (SATA150, NCQ, 16MB Cache) CD-ROM/DVD (E:) : N/A @ ATAPI iHAS324 A (SATA150, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard PS/2 Keyboard Mouse : HID-compliant mouse Human Interface : USB Human Interface Device Printers and Faxes Model : Microsoft XPS Document Writer Model : Fax Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows Vista Business Media Center 6.00.6001 (Service Pack 1) Platform Compliance : Win64 x64 Windows Experience Index Current System : 1.0 Network Services Adapter : Generic Marvell Yukon Chipset based Ethernet Controller Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
+ a million for XP. Also, I would roll back from IE8, as it has been causing many a DUCer problems.
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
Stuck on DAE Loaded | onature | Pro Tools M-Powered (Win) | 5 | 11-06-2013 04:42 PM |
PROBLEM within STRUCTURE, Starting transport makes Level of the loaded patches within | Chris7514 | Virtual Instruments | 2 | 10-27-2010 07:38 PM |
Stuck at DAE loaded, not ie8, cs10 for 7.4, windows xp | rucontent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-25-2009 02:05 PM |
PT7.4-PT8 Stuck On "DAE Loaded" on Vista 64-bit! | TK El Inginiero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-23-2009 02:56 PM |
"DAE loaded" stuck and PT LE doesn't launch! Please help! | Belfrahn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-28-2008 06:04 AM |
