Old 11-10-2004, 09:41 PM
sjmonty sjmonty is offline
Default How to combine 2 mono wav files into 1 mono file
There are many occasions where I have 2 mono wav files (2 hours in duration) that are need to quickly be combined/mixed together into a single mono wav file. Is there a faster way than "Bounce To Disk" to do this? I can't seem to find one in my 6.2.3 on OsX.
If not, do you know of an inexpensive stand-alone app that will do the same thing @ 24 bit 48k?
Old 11-11-2004, 12:34 AM
Paul Maunder Paul Maunder is offline
Default Re: How to combine 2 mono wav files into 1 mono fi
You can do this much more quickly than using bounce to disk. Just edit the two files together on the timeline and then rather than using the bounce to disk command, select the two adjacent regions and choose 'consolidate selection' from the edit menu (or press Shift+Option+3). This will then make a new single audio file from the original two and will appear on the timeline and in the audio regions list. Next go to the audio regions list, select the new full length audio file by clicking it and then choose 'Export selected as files' from the regions list menu at the top. You can then save this to disk in whatever format you choose. Alternatively, you could just use the newly consolidated file straight from your sessions audio files folder if it's already at the sample rate/bit depth you need it to be.
Old 11-11-2004, 08:43 AM
Seeee Seeee is offline
I think he wants em summed.
Old 11-11-2004, 09:21 AM
Thank you for your help but I think you misunderstood what I'm trying to do. I may not have explained it well enough. I don't need to take two 2 hour files and join them end to end to create a single 4 hour file. I need to mix them together in place as if routing the two to the same mono output and create one 2 hour file. I've asked quite a few people and there doesn't seem to be a way. Maybe there's a plug-in? Quicktime will do it but only at 16 bit.
Old 11-11-2004, 12:41 PM
Sorry for misunderstanding your question. There is a way to do this, but it's a little bit fiddly:
First import the two mono audio files into your session.
Put them onto two mono audio tracks on the timeline, with both regions starting at the same location.
Ensure that the two mono tracks are centrally panned so you can audition what they'll sound like when combined together.
Next, use the trimmer if necessary to make the two files exactly the same length.
Rename one of them 'something.L' and the other one 'something.R'. This will make protools see them as a single stereo file rather than 2 mono ones.
Now select this 'stereo' file from the regions list and select 'export selected as files'.
By choosing to export it as mono, you'll combine the two, and much more quickly than bouncing to disk.
The only drawback of this is that you can't put in any automation data, and the relative level of the two files is fixed to whatever level they were recorded at. You could potentially change the level of one using the normalize plug-in to balance it out as needed before exporting. Anyway, I hope this helps.
Old 11-11-2004, 01:01 PM
You're trying to be so helpful that I hate to disagree but what you suggested doesn't work - at least in my version. I had tried that before but only had the option of Stereo and (multiple) Mono which saves 2 mono files which is what I started out with.
Old 11-11-2004, 10:35 PM
love666 love666 is offline
how about this
pan them both to hard left and choose multiple mono on the export
then you will still get two files but one of them will be the sum and one will be nothing
http://thisistherock.com
Feature Request: Combine two mono into one stereo track? cprescott1972 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-29-2020 11:31 PM
Any batch software to combine split mono .L/.R files into interleaved WITH metadata? Maskeeper Post - Surround - Video 8 12-23-2012 09:44 PM
one mono audio file when two mono tracks recorded bluerej Pro Tools M-Powered (Win) 0 02-06-2010 01:09 AM
one mono audio file when two mono tracks bluerej Pro Tools M-Powered (Win) 0 02-06-2010 01:06 AM
combine two mono files into one stereo file [solved] stmiller Pro Tools M-Powered (Mac) 5 05-25-2007 10:28 PM
