Possible to un-commit in 12.3 at any point?
Maybe stupid question:
Is it possible to un-commit (un-freeze) at any point to get the original state of the track back? I thought the point of freeze is that it is "in place" and when you want to tweak things you simply un-freeze and re-freeze, no? Thanks, Frank. EDIT: sorry, just saw that commits are to a new track. strange... so basically it's the same as offline bounce but you don't have to go through the questions where you want the result (clip-list, track etc.)? So if I decide to delete the un-commited original there's no way I can ever go back to the un-committed state?
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Pro Tools 12.3 is out Now!
Otherwise, 99.999999999% of the time, you'll do Hide and Make Inactive for the uncommitted track so you have them both. This frees up CPU, delay comp, and "future proofs" the track. Freeze, coming later, will be for tracks that you'll be continuing to work with and will need to Freeze and unfreeze. When it's all in place, the user will have a great set of tools to handle whatever they need IMO. |
The hide-and-make-inactive-thing in a post-workflow is quite an adventure. With multiple hundred tracks to do house-keeping on I don't see me doing that for the committed tracks and originals. Maintaining the tracks I have now is quite a challenge on a system that doesn't offer sequence-handling, bins etc. Not sure if this commit-and-keep-original-workflow helps with that. If there's some kind of intelligence when the committed tracks knows which original is belongs to that's something else. But if it's the usual .dup1 .dup2 etc,. workflow I'm not sure if that helps keeping things uncluttered. Without having seen it obviously it sounds like it creates even more house keeping work...similar to using playlists in post.
Re: Possible to un-commit in 12.3 at any point?
Freeze is coming. But this is a really good solution for tracks you are finished with. While technically you could already do all of this, being able to do it in one step is a big time saver. Especially since you can do multiple tracks at once.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
I've tested this with Trigger and Melodyne and it's all working perfectly.
I am assuming no commit functionality for UAD plugs?
Sure you can. It may slow the offline bounce a little. I just committed a track with hardware inserts.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Yes but because of their oversampling, it's slow.
Realtime of course!!
How do Insert an in point and out point in my tracks and play this as a loop. | scottee | Windows | 2 | 08-15-2012 08:08 AM |
To Commit or not to Commit, that is the question. | georgejw22 | Pro Tools 10 | 10 | 12-20-2011 05:30 AM |
How to commit? | Louisblanc | Pro Tools TDM Systems (Mac) | 5 | 04-23-2009 04:26 PM |
Floating Point/ Fixed Point/ Dither | Nika | Tips & Tricks | 2 | 02-15-2005 12:05 PM |
