Error -7101 multi track record
My system:
d24 mix farm DSp farm 888/24 888/16 adat bridge/24 SSD PT 5.1 when i use the d24+mix farm 64 engine, i can't record more then 8 tracks, as soon as i select the 9th track i get a -7101 error (voice allocation) message. but all is OK when using the D24 32 voice engine .. also, i just did a Digitest for the first time and it tell me my setup is wrong (which its NOT) and when i continue the scan it gives me a -12 error message on my Mix Farm Card, and stops scanning. my system is work fine, all three my cards show up ok the my system usage window.. can anyone help ? Thanx adam |
Re: Error -7101 multi track record
What are the order of your cards? The slot order for a Mix Expanded PT|24 system should be:
1-Mix Farm 2-d24 3-DSP Farm -Whenever you switch the order of your cards, it is a good idea to trash the DigiSetup file and restart. -Search the AnswerBase for error -7101 and see if any of the records apply. Brent |
how do i multi track record off mpc to protools? | Achillesthagr8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-25-2010 05:50 PM |
Multi MIDI Track Record | miek07 | Tips & Tricks | 0 | 03-06-2007 03:59 AM |
dae error 7101 with pt5.1.1 on win2k | bigdude | Pro Tools TDM Systems (Win) | 3 | 07-23-2001 11:47 AM |
error -7107 multi track record | SOR | General Discussion | 0 | 06-08-2001 10:01 PM |
DAE Error 7101 | GS-DK | Pro Tools TDM Systems (Mac) | 5 | 01-28-2001 02:38 PM |
