dae error 7101 with pt5.1.1 on win2k
i understand from the web answerbase that this is a problem with dae when 1622 is first and is fixed in beta version of dae....
i have 1622, 88824 and adat bridge cards are mix core, mix farm and mix i/o 1622 is connected to mix i/o 88824 and adat A are connected to mix core adat B is connected to mix farm why does pt take the "first" i/o to be connected to the mix i/o? i would think that it would take the mix core i/o to be "first".... if i don't want to use the beta dae, do i have to physically change the connection on the back of the cards to the i/o boxes to change who is "first"? if i use the beta dae, how is it working on win2k pt? thanks in advance [ July 17, 2001: Message edited by: bigdude ] |
Re: dae error 7101 with pt5.1.1 on win2k
ok....so the beta is only on mac
digi, any idea when windows will get a fix for this??? thanks |
Hi there,
you can't connect the ADAT bridge across two cards. Each unit with 16 inputs or outputs (Adat Bridge, 1622) will have to be connected to a single Pro Tools card. You can put two units with 8 inputs or outputs (888/24, 882/20) on a single PT card using a y cable. The 1622 on the MIX I/O card is the only unit that is wired correctly, so it is chosen first. In your setup, the best (I think) way to connect would be: Mix Core -> ADAT BRIDGE MIX FARM -> 1622 Mix I/O -> 888/24 This way the adat bridge is clock master and the other units will slave to it, which is useful for instance when you're connecting to a digital mixer. All this will work with Pro Tools 5.1 1 under Windows 2000, *if* your PC conforms to http://www.digidesign.com/compato/pt24perfwin.html |
hi increddibelly!
thanks for the info makes alot of sense that way cheers |
DAE Error 7101 and 7100 on Mix system | Hive Guy | Pro Tools TDM Systems (Mac) | 0 | 12-22-2006 12:26 PM |
dae -6 error in 5.3.1 win2k | jadd | Pro Tools TDM Systems (Win) | 2 | 08-01-2005 05:51 AM |
Error -7101 multi track record | SOR | Pro Tools TDM Systems (Mac) | 1 | 06-11-2001 05:07 AM |
DAE error was encountered while trying to connect (error #-7101 | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 12:45 AM |
DAE Error 7101 | GS-DK | Pro Tools TDM Systems (Mac) | 5 | 01-28-2001 02:38 PM |
