default midi instrument
I was wondering if there is a way to setup the default midi instrument to ALL channels.
I have a digi 002R and a XP-50 connected to it. It's currently setup so that I can only assign one channel at a time on the default midi instrument. I would like to set it to all channels to midi thru. Can this be done? and how? My options are: XP-50 channel 1 XP-50 channel 2 XP-50 channel 3 XP-50 channel 4 XP-50 channel 5 XP-50 channel 6 XP-50 channel 7 XP-50 channel 8 XP-50 channel 9 XP-50 channel 10 XP-50 channel 11 XP-50 channel 12 XP-50 channel 13 XP-50 channel 14 XP-50 channel 15 XP-50 channel 16 I would like a XP-50 channel ALL How can I do it? |
Re: default midi instrument
Can anyone help me?
Can you explain further what you are trying to accomplish? So far you're not making any sense, but maybe this will help...
A MIDI track in PTLE can only be assigned to output to a single MIDI channel - this is the way that MIDI works, otherwise you would be playing 16 channels with a MIDI command, which would result in a cacophanic mess. |
Ok This is what I am trying to do. I would like to use my MPC 2000 and as a sequencer for my Yamaha Motif Rack and my XP-50. The way I have it connected is as follow:
(DIGI002R)OUT ----------------------------------->IN(XP-50) (DIGI002R)OUT---------------> IN(SYNC ONLY)(MPC 1000) (DIGI002R)IN<---------------- OUT(MPC1000) (XP-50)THRU------------->IN(MOTIF R) (MPC 1000)IN<---------------- OUT(XP-50) I want to be able to use the Multi from the XP-50 and the MOTIF. So when I setup the default Instrument for XP-50 Channel 1 I can only hear channel 1. I need to have an option of XP-50 - ALL in order to hear all 16 midi channels. Also I would like to use the sequencer in PROTOOLS whenever I need to. Maybe I am doing it wrong can someone help me? |
Anyone has any suggestions?
Default MIDI Thru Instrument doesn't stick | wyman | Pro Tools 10 | 3 | 05-12-2014 07:50 AM |
Default Thru Instrument | Keith Moore | Pro Tools TDM Systems (Mac) | 0 | 03-02-2012 09:45 PM |
Default Thru Instrument doesn't save with session? | HearInc | Pro Tools TDM Systems (Mac) | 6 | 08-25-2010 08:12 PM |
default thru instrument | pedmunds1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-17-2005 11:18 AM |
"Default Midi Instrument" bug? | lwilliam | MIDI | 1 | 03-23-2001 12:44 AM |
