82 byte tokens ???
have you ever had the error "protools ran out of 82 byte tokens" ? This is when it's hooked up to procontrol and is slaving off 9-pin control.
I'm in desperate need for a fix ! -cd |
Re: 82 byte tokens ???
Charles,
If you call your local Digi Support team they'll be able to write you out a file that you place inside your DAE Folder. They did this for me and it sorted out the problem. Basically DAE run's out of data packets of certain sizes and this file tells DAE to make more etc!! Good Luck! |
82 Byte tokens | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-21-2007 01:59 PM |
OK ! So what is "PT ran out if 82 byte tokens" ? | priorytools | Pro Tools TDM Systems (Mac) | 2 | 01-04-2007 04:55 PM |
82 byte tokens? | IO Composer | Pro Tools TDM Systems (Mac) | 4 | 01-07-2005 03:21 PM |
22 byte tokens? | rsgl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-22-2002 11:48 AM |
Out of 82 Byte Tokens | Davinci | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-03-2002 05:50 PM |
