Old 03-17-2017, 04:09 PM
theom theom is offline
Default Midi Pitch bend plays notes
Pt 12.7
Mac Mini server 16GB Ram
Yosemite
KX88 controller
USB cable generic midi cable midi interface
With any soft instrument a midi pitch wheel event causes a few dozen notes to play.
I reset the KX88
I dont have another midi controller to check
Is this a known issue?
Old 03-18-2017, 05:44 AM
Default Re: Midi Pitch bend plays notes
Get the free snoize MIDI monitor utility and use that to see what exact messages your controller is sending out. You don't need or want to have PT running when doing this. If you get the right MIDI messages then you'll have to look elsewheres. It also helps to know what the MIDI message are supposed to be.
Snoize link: http://www.snoize.com/
MIDI messages links: http://www.midi.org/techspecs/midimessages.php
http://web.archive.org/web/200707021...ntrollers.html
http://www.nortonmusic.com/midi_cc.html
Jack
QAPLA!
Old 03-18-2017, 11:09 AM
Exactly what I needed.
Thanks,
My KX is outputting "note ons" rather than pitch bend.
It is 30 years old so......
Old 03-28-2017, 04:20 PM
In case anyone else has this issue:
It is a KX-88 issue.
The internal clocking can conflict with the midi clock.
There is a magic start up combination to disable the KX internal clock.
Hold down MODE while powering up.
This and other great KX88 info was found here:
https://validopinion.wordpress.com/2...a-kx88-issues/
Thanks ValidOpinion
Edit pitch bend midi data bwandon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2018 08:20 PM
Pro Tools LE 8 Midi Pitch Bend Problem W Sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-09-2011 02:09 PM
MIDI track not reading pitch bend data? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-11-2009 07:04 PM
MIDI Pitch bend question, please? William 2014 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-30-2006 11:53 AM
MIDI : Pitch Bend Muxlow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-01-2003 09:28 PM
