#31
Re: Pro Tools 12 vs Studio One 3 vs Logic Pro X
Here is another thread with input buffer information:
http://duc.avid.com/showthread.php?t=347456 I've searched the manual also, and for all the talk about "input buffer", the phrase never comes up once in the reference guide, so they clearly are behind the curve on that. I also suspect that the error message that comes up saying "increase your buffer size" when you have a freeze isn't correct or at least worded properly to minimize confusion. Recently I still saw posts here saying that if you were having playback issues, increase this buffer ANYWAY because it seems to help. I think there's a lot of confusion about this; someone theorized that auxes sometimes are considered input paths, even if they're coming from internal sources. I don't mean to hijack the thread, but I find the lack of clarity and the deficient documentation about this annoying.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
#32
I think for composition and music production there are better solutions. My favorite at this point is Studio One V3. For music production, it's fast, lean, and you get tons of (over 80 gigs) of extras. I still use Pro Tools and will probably for a long time. I just had to justify a different DAW as my primary...
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
#33
I have upgraded to 12 as I have clients who want the latest (I also have 10 and 11). I will admit that personally, I am more of a Logic Pro X person. But customers who rent the facility want to use Pro Tools. So, I decided that I needed to really start learning and using PT since I have invested so much in to Avid.
So two weeks ago I moved an album project wav files into PT folders and started to mix (first in 11 and now in 12). I am now struggling with mixing in Pro Tools and having the CPU crash - all the time. At this point, speaking in Logic Pro X terms, the current track / plugin count doesn't even make Logic breath hard AND I have just started - got a call into Avid support. But if this is my fate every time I do a mix - hell I am going back to Logic for good. How do you guy's get around this? In Logic with Thunderbolt connected to my symphony I can record and mix down with 32 Buffers - 1024 in Pro Tools is insane especially if the artists needs to come back and do over dubs. But I am not even there yet!!! Just trying to do a mix how do I stop my CPU from overloading - meters only show 12% |
#34
Also, wording does probably need to be changed if that's the case. If this buffer is not the playback buffer, but the input buffer, then why is it in the playback settings window?? Must be a legacy thing... |
#35
Seriously, they ask for PT 12 over previous versions?
#36
Sorry wish I could help, but I too have this exact same issue. I find its plugins and busses generally. I know if Logic and S1 they're not a problem, they somehow seem to be though in Pro Tools. I have recently removed absolutely every program off my computer that I do not NEED, removed everything from startup, uninstalled all other system tools that I can live without, and went through the optimisation guide again. So far I've been having better luck. It just appears that in order to use Pro Tools, you need a dedicated machine that does nothing else. As I stated (from my 30 years of programming experience), Pro Tools appears to be poorly optimised for today's processors. Things that don't even make my Mac break a sweat in Logic and S1 make Pro Tools very nearly buckle. I've already had to replace the logic board in one mac from what I can only assume is constant CPU load/fanspin as the chips basically fried on it. Since the only thing I did on my computer that put any strain on it was Pro Tools, I can only assume that Pro Tools in the culprit. It's a Macbook Pro, I don't play games on it (I have consoles for that), and other than that, just programming and office work, which does not put any load at all on a core i7 processor with 16GB of ram. To shorten it up, remove everything you can live without and pull everything out of startup. Follow this guide: http://avid.force.com/pkb/articles/t.../Optimize-10-9 It does help, if only just. I still get occasional playback errors at 1024 sample size, but at least I can get through sessions. |
#37
I personally don't think it's a cpu time slice issue with PT. I really think it's a time slice issue with the AAX format. I really believe Avid shot themselves in the foot by not allowing 64 bit VST's. This caused the devs to make hasty 'patches' to their RTAS and the ones that had VST's as RTAS. I also think it has something to do with the way the copy protection works with AAX and iLok vs VST's and simpler licenses. IMHO this is why when we have to find a misbehaving plug we have to do the move the plugs into the unused folder and move them back one at a time dance. When PT starts, it loads what I can only assume is a license stub that I suppose is checked with the iLok for every plug you own. For users with lots of plugs, that's lots of memory and lots of cpu cycles to attend to. If one of those plugs has a poorly written interface it may hog the cpu even if it's not being used in the session. Also, I think the guy that wrote the AAX spec is no longer with Avid. The reasoning behind the above is now that I've been using a different DAW and VST, VSTi's, VST3, and AU plugs which don't have those licensing constraints the DAW just feels more mobile and responsive. Just my $.02 and educated conjecture, purely empirical and loosely defined.
#38
#39
That's what I've been doing for years without a hitch and I live further away than you.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
#40
I needed a iLok when I purchased it, so I had to find and get in touch with a local supplier to get a hard copy of Pro Tools with an iLok. Some local suppliers can be a pain in the backside to deal with. Since then though I agree, the purchase process has been smooth sailing. :) |
Help Slaving Logic Studio to Pro Tools | Premo | Pro Tools TDM Systems (Mac) | 124 | 05-08-2014 08:35 AM |
Pro Tools 8 le, logic pro 9 and studio one pro | barry1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-05-2010 05:38 AM |
Logic Studio taking files to pro tools studio. | smoochdaddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-30-2009 10:55 AM |
Pro Tools LE after Logic Studio | PT fan002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-25-2007 04:44 PM |
I invite Pro Tools users to use ProControl studio but most of them use Logic????????? | Jules | ProControl, Control|24, Command|8 | 37 | 12-07-2000 12:10 AM |
