6.7 and ProControl and Glidepoint mouse
Just wondered if anyone else has experienced this upgrade problem:-
Since the upgrade form 6.4 cs xyz to 6.7 the Glidepoint mouse on my Procontrol has stopped functioning correctly:- 1) The only way to make it move the pointer is to keep my finger on the left mouse button whilst moving my finger around the pad 2) A single left button click is now achieved by pushing both mouse buttons simultaneously All else is fine, in fact superb, a great update Digi! (apart from my mouse of course) N. |
Re: 6.7 and ProControl and Glidepoint mouse
Wow! you actually use it?
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
Yes I do! - Well uhh, I mean no I used to use it pre 6.7 that is. Why don't you?
News from Digi is that I've found a bug which has been duly noted and brought to the attention of the development folks across the pond. N. |
FYI - Reply from Digidesign tech support - Just in case you have the same problem.
N. -------------------------------------------------------------------- Thank you for the information. I have recreated this problem with our PT 6.7 setup and can confirm that this appears to be a bug within the software. I have forwarded your details and problem to our engineering team in the US who will address the issue. I'm afraid I was unable to find a workaround that would allow you to use the Glidepoint mouse in the meantime Stuart Page Technical Support Specialist --------------------------------------------------------------------- |
its now january, and no fix. I just installed 6.7cs5 and 10.3.7 and its not working. There are ittermittant problems
with other buttons as well. |
Trackball Mouse with Normal Mouse Operation | dstryrwiz | Windows | 0 | 05-27-2011 11:30 AM |
Procontrol mouse-down error | bavc | ProControl, Control|24, Command|8 | 18 | 06-10-2008 09:24 AM |
7.3 and ProControl | RobMacki | ProControl, Control|24, Command|8 | 12 | 04-09-2007 02:52 PM |
ProControl | scot charles | ProControl, Control|24, Command|8 | 0 | 12-09-2001 05:11 PM |
ProControl Keyboard/Mouse Question | tonyespinoza | General Discussion | 1 | 08-08-2000 01:25 AM |
