A little experiment
Ok me and my commrade are trying something. We want to sync Pro Tools on my computer with DP on his computer using MTC. PT is Master and DP is slave. What Frame # do I use? Do I use the same number on both programs or just one. Is midi clock better. Suggestions? Were going to do this asap.
Re: A little experiment
MTC does not have sub frame info in the Timecode
Just us PT Sync I/O to stripe a track with TC and then slave the PT to the DP TC track
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Without sync I/O it is possible, send MTC from PT (framerate does not matter, as long as it is the same on both) via IAC. You can set this up it the session setup window, under the windows menu. How it is setup in DP I have no idea.
An experiment | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-07-2007 10:34 PM |
A performance experiment... | JMS40 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-27-2005 09:35 PM |
Experiment...? | go i huvet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-18-2002 02:59 AM |
I just tried a SRC experiment; | dkrausz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-11-2002 06:59 AM |
An experiment... | Kamurah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-12-2001 02:22 PM |
