Old 10-26-2017, 06:18 AM
flautista's Avatar
flautista flautista is offline
Default speed play back issues
hi everyone
My PT plays at double speed or too fast
I can fix with shorcut, but in the next time or new session get wrong again
Is a way to setup the speed by default
or save some preferences
please help ,thanks
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 10-26-2017, 08:57 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: speed play back issues
Sounds like a sample rate mismatch. Check your interface and session sample rates. Do they match?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-26-2017, 09:54 AM
_JJ_ _JJ_ is offline
Yes, sounds like a sample rate issue. I ran into this recently - started a new session in 48k and imported audio from an mp3 which must have been 44.1. Instead of converting the file PT just brought it in and then played it back at the higher pitch and speed. I can't think of a situation where one would ever WANT this to happen so it seems SRC should be the default when importing audio...
How to play back faster than 1X speed? wevets Getting Started 5 04-16-2022 07:06 AM
How do I adjust play back speed? SWBoatman25 Getting Started 1 03-06-2015 10:59 PM
PT sessions sometimes play back at slow speed moogsy Pro Tools TDM Systems (Mac) 2 03-15-2006 08:24 AM
PT sessions sometimes play back at slow speed moogsy Pro Tools TDM Systems (Mac) 0 03-14-2006 04:58 PM
why does song play back at faster speed? meeksmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-29-2003 01:15 PM
