Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
Old 08-07-2019, 01:15 PM
J-S-Q J-S-Q is offline
Default Can I replace faders myself?
I see replacement faders available online but how difficult is it to install them. Specifically, does it involve intricate soldering on a PCB?
Old 08-07-2019, 05:53 PM
mattrixx mattrixx is offline
Default Re: Can I replace faders myself?
Don't quote me on this, however, I did read sometime back that they were relatively easy to swap out. (by removing the bottom panel, they are quite accessible).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 08-07-2019, 08:37 PM
BScout BScout is offline
Pretty clearly a multi-header connector to unplug/replug.
https://www.fullcompass.com/prod/503...otorized-fader
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD Omni • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Last edited by BScout; 08-07-2019 at 08:38 PM. Reason: not truly a ribbon cable so corrected.
Old 08-08-2019, 05:15 AM
Jamie Mac Jamie Mac is offline
It's very easy to replace or clean the faders yourself. Just open the back with a screwdriver and pop out the faders.
Be sure to first try and clean them. As sometimes it's just dirt stuck on the track that is the culprit. You would be surprised how much dust and dirt falls in there.
Old 08-08-2019, 09:34 AM
reichman's Avatar
reichman reichman is offline
+1 easy to replace faders on an S3. Gives me confidence that I'll be able to maintain my S3 without having to send it back to the mothership.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 08-10-2019, 06:55 AM
Great. Thanks all for the replies.
Old 08-10-2019, 08:02 AM
Southsidemusic's Avatar
+1
We had thought we had to swap over half of the ES32 D-Control Faders but we followed a youtube video and sfter a good clean out of ALL faders and the tracks they run on ALL faders were 100% again so not a cent was spent, only a few hours of meticulous cleaning and dust sucking with a small USB vacuum cleaner on a long thin telescope arm
4 hours later and a LOT of those cotton thingies people use to clean the ears inside with and those packages was like 2 USD a box so 250-ish ”tops” used and we spent less than 5 bucks on that whole fix !!
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 08-11-2019, 12:52 PM
Originally Posted by Southsidemusic View Post
+1
I don't suppose you would happen to recall the Youtube video?
Old 08-11-2019, 01:18 PM
I will ask the techie guys who interned here last year before we sold the ES32 and I am sure one of my brothers knows where it is so I’ll be baaaaak
Best Regards
Christopher
WEBHOME
Old 08-11-2019, 07:13 PM
Actually no need to find that video. I spent some time cleaning the problem faders and in fact they all now work perfectly which is great! Very easy indeed to remove them and reinstall. One of them took several rounds of cleaning/reinstallation before I finally removed all the dust but very happy that this has cost me zero!
Thanks. :)
Sticky Faders, GUI Lag when moving faders Intransit Pro Tools 12 10 02-04-2016 09:31 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 10:56 PM
2.7.1 - Mix window faders & MC Mix faders ? priorytools Artist Series 2 05-14-2013 03:37 PM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 07:44 PM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 08:06 PM
