Pro Tools 10 HD Native Memory Requirement ... More is Better?
It's looking like I will soon be moving to PT 10 HD Native.
My 8 core Mac Pro currently has 6 GB of memory. Would increasing the memory yield improved performance for the native card? If so ... is there an optimum memory size? It will hold up to 32 GB, but is that overkill? Thanks ...
Bob PT10 HD Native (10.2.0), 96 I/Os, C24, Mac Pro (10.6.8 / 16GB) |
Re: Pro Tools 10 HD Native Memory Requirement ... More is Better?
I've got 6 and its not enough! i'll be getting another 8 which should be plenty and enable me to assign 8-10 to the timeline cache and still have at least 4 gig left for the OS. Depending on what computer you have, ram is cheap for the new mac pro's. if you have an harpertown like then ram is still quite expensive. Chris
At 24 bit/48 kHz, a 5 minute song, where 100 mono tracks plays all the time, a 4 GB cache would be enough. Just sayin'.
Protools stills a 32 bit application so as far as I understand it will use a max of 4 gigs of ram except if version 10 has a mechanism that allow the 32bits application to use more ram but this is not something I've heard of.
2 gigs of ram should be enough imho for the os to run without a hiccup in the background. |
but he has a Native card so he can use the Extended Disk Cache so more is better
total RAM -3GB for PT and up to 12 for EDC I think
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Perhaps 16 GB would be a nice number?
I've read where it's best to have matching memory sticks. So, I guess that means pulling out the current 6 GB and installing new 16 GB sticks.
I have 4 minute songs with way less than 100 tracks and the session is nearly 4GB by itself. Plus, my session are all now in 32 bit rather than 24. (which means 1/3 larger) If you're on HD, I'd say 8GB of RAM minimum if you really want to be able to take advantage of disk cache.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Correct. RAM does not like to be mixed and matched, and the bottleneck will always be based on the slowest chip. Plus, modern computers tend to take advantage of pairs or 3s in terms of performance.
Also if your using VEpro or another app that's using RAM at the same time you might want to take that into account.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Hi there,
I've 16GB RAM with my Mac Pro/PT10HD Native setup and all is good. The mac had 12 when I got it, but figured an even number of chips was better (4 x 4gb) I've come from a HD3 Accel on G5 rig and am very pleasantly surprised! Check out UAD2 cards for some extra plugin fun ;-) Oh, running Lion 10.7.2. No problems so far. |
Pro Tools HD 10 Peripherals Requirement | elmaguey | Pro Tools 10 | 1 | 04-04-2012 05:17 AM |
Native Instruments Battery causing out of memory error | MikeC | Pro Tools TDM Systems (Mac) | 4 | 11-26-2002 12:59 AM |
Is USB a requirement for XP? | Pierre B. Samson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-28-2002 03:34 AM |
Is USB a requirement for XP? | Pierre B. Samson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-27-2002 09:16 PM |
RAM Requirement | Mount Royal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-05-2001 03:45 PM |
