Old 02-26-2019, 08:30 AM
onosendai onosendai is offline
Default Unable to play audio using Shuttle mode (SOLVED)
Hey
I've always used Shuttle mode, using the numeric keypad to scrub audio, but for some reason it stopped working and I have no idea why
This is what happens: I only hear a short blip of the clip audio and then the transport controls just blink afterwards and pro tools kind of seizes up for a couple of seconds depending on how long I've held the numbpad down. Either no audio is playing or it just repeats the initial samples.
I trashed preferences and it didn't help. Has anybody else experienced this?
SOLVED:
make sure your mechanical keyboard does not use a key-repeater function if your using Shuttle mode.
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802
Old 02-26-2019, 06:24 PM
Default Re: Unable to play audio using Shuttle mode
Review preferences. Pretty sure there is a checkbox that allows audio during FF and RW. If you recently trashed prefs, it would probably default to unchecked(good time to review other settings there as well)
Old 02-27-2019, 06:24 AM
Hey Albee,
Thanks for the suggestion. I tried and I actually found out Shuttle mode works independetly whether that option is ticked or not. It's only relevant if you use the transport controls directly.
I found the problem after a painful process of downgrading to 2018.10 and back, total plugin nightmare. I ended up testing usb hubs, reading manuals and shuttling with my old apple keyboard and the last one worked(!?). So I eliminated it to be my mechanical keyboard (Coolermaster Pro L), which is a gamer keyboard and it apparently has a key-repeater function that I had somehow activated. Activation is not discernable unless you enter a custom keyboard state that lights certain keys.
So whenever I held down a key like one does in Shuttle mode I was spamming Pro tools with x8 the input that would increase continuesly with the time a key was pressed, which is what made it completely fall over and stop working.
SOLVED: make sure your mechanical keyboard does not use a key-repeater function if your using Shuttle mode.
Audio unable to play from other applications freetonade Pro Tools | Intro Discussion 1 01-05-2017 11:42 AM
003 randomly goes into shuttle mode Ironbear9 Pro Tools 10 1 09-05-2013 11:53 PM
shuttle mode for PTLE Dingo90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-28-2009 05:34 PM
recording in shuttle mode nate9 ICON & C|24 1 03-24-2009 11:04 PM
can't hear audio with track in play mode slim chrispy Tips & Tricks 2 06-08-2004 07:06 AM
