why can i record even when rec is armed?????help
ok guys i had a problem and i'm halfway solved it..the only problem now is that when i arm a track in record mode.then hit spacebar,my triton plays but it doesnt record onto protools...the same problem with my mpc..it was doing it fine before but the other night i was drunk and dont know what i did to prottolls now it wont record even when the track is armed!!!!!!
help me pleasee [img]images/icons/confused.gif[/img]
M.O.B. |
Re: why can i record even when rec is armed?????help
Yeah what he said or just hit 3 on the numeric keypad...I've always found it easier...
Some music?... http://tmweb.free.fr |
Lets check basics first....
Are you trying to record to a midi-track or an audio-tarck? A midi-track will only record midi-messages....wich is not the actual audio. To record the audio, you have to connect a lead between the audio-out of you midi-device and an audio-input of the digi001. From your post i think you have the midi-connections made corectly....
What's that? - That's the machine that goes "pling". Bastiaan |
Try getting really drunk again and messing around with PT.
Sometimes, when we retrace our steps..... [img]images/icons/wink.gif[/img] dk
http://homepage.mac.com/dkrausz |
I feel MUCH better right now. |
try holding down the "apple" key" while hitting the space bar. That Might do the trick....if it doesn't, maybe somebody more technical than me can help.
Pat |
How do i add effects to a record armed track? | Gravy | macOS | 3 | 11-29-2011 01:16 AM |
Keep record armed? | lambono | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-04-2011 02:41 AM |
No sound from mic when armed for record | GMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 29 | 02-23-2009 07:31 PM |
Record Armed + Play - stops | Scorpio253 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-23-2007 02:45 AM |
Record armed track leveling | dancheung | Tips & Tricks | 2 | 03-26-2007 08:39 PM |
