Mbox2 noise floor has large negative DC-offset
My MBox2 line input 2 is showing very unusual behavior. The recorded noise floor, with no inputs attached has a large negative DC offset. Line input 1 is fine.
Is any familiar with this issue? System is a Dell Dimension 5150C, WinXP, PTLE 7.3.1cs2, latest drivers, etc. |
Re: Mbox2 noise floor has large negative DC-offset
Hey I don't have an answer to your problem. I just want some info.
I just got protools set up on a Dell 5150c and I need to know if you have an integrated video card, or are you using onboard video? I know the last time you were on was 3 years ago, but maybe you have your email set up to notify you... I hope this works... |
Delay Compensation, User offset negative | HiLoc | Pro Tools TDM Systems (Mac) | 4 | 04-03-2010 01:18 AM |
Negative Video Sync Offset??? | admix | Post - Surround - Video | 3 | 05-15-2008 10:34 AM |
Negative "User offset" ADC numbers possible? | Tim R. | Pro Tools TDM Systems (Mac) | 1 | 06-19-2007 03:14 PM |
negative feet.frames offset? is it even possible? | sndgeek | Post - Surround - Video | 7 | 06-20-2004 11:27 PM |
Noise floor (Signal to Noise Ratio)...Please explain this term | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-05-2001 12:54 AM |
