Multiple outputs with Kontakt in 6.7?
I've searched the DUC and NI forums and I can't find a straight answer to this.
Can you use multiple audio outputs from a single instance of Kontakt in PT 6.7? If not, what RTAS samplers do support this new feature of 6.7? Thanks, Jason www.chromasound.net |
Re: Multiple outputs with Kontakt in 6.7?
Reason 2.5 certainly gives you multiple outputs via Rewire, so you can have separate outputs from the NNXT or run multiple NNXTs. I don't think thats really what you're asking, though.
The only VI I have that seems to support it directly is Stylus RMX. You can tell right away because on a Stereo Aux track input selector, you will see a 3rd option for "plug-in" that is usually greyed out, but if you have a plugin that supports multiple outputs in 6.7 and it's loaded somewhere, then you'll see the additional outputs available from that plugin.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Multiple outs in Battery 2 works in Pro Tools LE 6.7 - after assigning different cells to different outputs (ie overheads to a stereo pair, room mics to a stereo pair) you can then open up another stereo aux channel and in the input channel, you get a choice of I/O, buss or Battery different output - worked great with 4 total stereo tracks in battery:
kick and snare on 1-2 hihat and cymbals on 3-4 Room mics on 5-6 Overhead mics on 7-8 This has opened up totally new doors on Battery and now I'm back in love with this sampler as well as being able to mangle the sounds more and mix easier. Great feature!
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
regs
last: PT11.3.1 |
Thank you very much.
Jason |
Routing to unassigned Kontakt outputs | Starting User | macOS | 1 | 10-28-2012 02:05 PM |
Kontakt 3 Outputs in Pro Tools LE? | smc917 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-17-2008 07:05 PM |
Kontakt 2 Multiple Outputs | Safjuan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-05-2008 08:21 AM |
Assigning Kontakt outputs to Instrument track in PT | sky88dd | Virtual Instruments | 0 | 09-27-2007 03:34 PM |
Multiple outputs for multiple players. | KingFish | ICON & C|24 | 1 | 05-08-2004 01:13 PM |
