Looking For: MIDI Pattern Generator
I need to create a whole bunch of random 1-3-5-Octave arpeggios. I could make them myself BUT what would be nice would be a pattern generator that I can get to output to MIDI.
That way if I like 95% of the pattern, I can change the small parts I don't like. It will also enable me to line these patterns up on an Instrument track as I audition sounds. As you can see in the attached screenshots, I have Omnisphere, Xpand!2 and FM8 - all of which have arpeggiators with a "Random" setting, but no way to generate that pattern into MIDI information. FM8, for example, will play the same 32-step "randomized" sequence over and over, and I could save that as a preset, but then I'm limited to just the sounds in FM8 AND 32 steps. It would be nice to be able to output that pattern to MIDI so I can layer it with other synths. Anyway... help? Suggestions?
iMac 27"; 4.0Ghz Intel Core i7; 16GB RAM; Pro Tools 2019.12 Last edited by SoundByLaura; 05-01-2018 at 12:47 PM. |
Re: Looking For: MIDI Pattern Generator
And the answer is Cthulhu.
iMac 27"; 4.0Ghz Intel Core i7; 16GB RAM; Pro Tools 2019.12 |
Yeah I was gonna suggest the same. There’s a couple of other ones out there, but the names slip my mind. Sent from my iPhone using Tapatalk |
Midi sequencing/pattern recording..help me!! | Tragon | The Drum Room | 2 | 07-01-2012 03:30 PM |
MIDI pattern + External Synthesizer | typhy | macOS | 3 | 11-28-2011 07:13 PM |
I need a flexible RTAS pattern generator/slicer/ | Infiltrator | Virtual Instruments | 9 | 08-31-2010 09:01 AM |
Converting a Pattern to MIDI | samskimusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-29-2010 12:04 PM |
midi drum pattern library ? | tantejo | Tips & Tricks | 4 | 01-10-2006 05:47 AM |
