Old 02-13-2019, 02:10 PM
edison edison is offline
Default Issue With Using Second Monitor
I just changed from a pair of 15 year old flat screens to two (2) new monitors, an HP and a AOC. My PC has a nVidia Quadra 980XGL display card.
My problem is, I can't get the "edit screen" or anything from Pro Tools to appear on the second monitor. The second monitor works fine on the PC "desktop"
I have Pro Tools HD TDM running on an HP Workstation running Microsoft XP.
How do I get Pro Tools to recognize/use the second monitor? Also, what screen resolution should I use?
Thanks...
Old 02-13-2019, 02:39 PM
Top Jimmy's Avatar
Default Re: Issue With Using Second Monitor
Don't you have to extend the Pro Tools window across both monitors before you can have the edit or mix window on one or the other?
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 02-13-2019, 03:05 PM
Brilliant! Thank you...
There is nothing more deceptive than an obvious fact.
Arthur Conan Doyle
Old 02-13-2019, 04:24 PM
Top Jimmy's Avatar
I don't know how relevant this still may be, but Skootch was (is?) a popular utility for running Pro Tools on Windows.
https://www.youtube.com/watch?v=lSITr74hP0I
James Cadwallader
Old 02-13-2019, 05:03 PM
Never heard of it. I use PT mostly for sound design and development. Will check it out. Thanks...
PS do you have recommendation for the optimal monitor setting to work with pro tools? The AOC manual recommends 1024 x 760 for XP? Ratio?
Old 02-13-2019, 08:47 PM
Top Jimmy's Avatar
1024x768 is a 4:3 ratio. I always use matched displays on my dual display setups and I always set them to use their native resolution.
James Cadwallader
Old 02-14-2019, 05:37 PM
Media Man Media Man is offline
Go with the recommendations of the monitor manufacturer for each monitor. Pro Tools does not care.
Media Man
Issue with 4k monitor johnb8511 General Discussion 1 01-20-2018 05:33 AM
RX4 Monitor authorization issue David Sandwisch AAX Plug-ins 1 09-30-2014 04:28 PM
Dual Monitor Issue ducada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-11-2009 07:43 AM
CTRL 24 Mac OS X Monitor Issue MikeyK Pro Tools TDM Systems (Mac) 3 01-21-2009 09:45 AM
monitor issue m-box cmattle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-30-2005 04:14 AM
