Old 04-30-2013, 10:47 PM
Rjones17 Rjones17 is offline
Default How do I export to mp3 file? (PT10)
I can't seem to find where I need to go in the software to export a session to an mp3 file. I had thought with Bounce To Disk it would allow this. It was my understanding PT 10 (I have 10.3.3) included an mp3 Export Option. I would appreciate any input on how to make this work. - Thanks.
Old 04-30-2013, 10:55 PM
guatamas guatamas is offline
Default Re: How do I export to mp3 file? (PT10)
That's exactly where you do that File/Bounce To Disk.
There is a drop down menu, as it defaults to .wav and if your recording or mixing in a higher sample and bit depth change those to 44.1 and 16-bit
Old 05-01-2013, 07:12 AM
Or if you bounce at the session sample rate and bit depth, and choose to import the bounced file into the session, you can then use the Export Clips as Files command and select mp3 as the outgoing format.
Known PT10 export corrupt wav files?? Rockman413 Pro Tools 10 9 11-03-2012 05:23 PM
once again--OMF export from PT10 to other systems? philper Post - Surround - Video 0 10-31-2012 09:42 AM
Export Multichannel Interleved Files - Major Bug in PT10 evs Post - Surround - Video 40 08-18-2012 06:49 PM
mp3 export doesn't show correct file size til another export done obidon Pro Tools TDM Systems (Mac) 0 12-09-2010 01:13 PM
How to export to a wav file? lonlonmilklover 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-05-2006 08:42 PM
