Old 01-25-2020, 04:31 AM
Auggie Auggie is offline
Default Pro Tools 19 not match Duet firmware
Hi, I hope someone gives me a solution to my problem:
I just bought Pro Tools 2019.12 with perpetual license but when I connect my
Avid / Apogee Duet (2017) the following message appears on the screen:
Duet firmware does not macht the installed Avid software.
Please run the Pro Tools Duet Firmware Updater found in the Applications > Utilities folder.
I have updated the Duet firmware to 0.2.68 And yet the message remains the same.
Maybe this version of Pro Tools works with an older firmware?
I can control my Duet interface but I can't work with two inputs. I only have one asset. Can this have to do with this question?
I have been searching the forums for days and have tried everything they say but I still do not solve the problem.
Any suggestions?
Thanks!
Here are my specs:
MacBook Pro (Retina, 13-inc, Late 2012)
2,5 GHz Intel Core i5
MacOS High Sierra 10.13.6
8 GB 1600 MHz DDR3
Pro Tools 2019.12
Pro Tools Duet (black) (2017)
Old 01-25-2020, 04:44 AM
musicman691 musicman691 is online now
Default Re: Pro Tools 19 not match Duet firmware
Try this: hold down the 'n' key on your computer keyboard and then select your audio interface.
Old 01-25-2020, 07:57 AM
The Weed's Avatar
The Weed The Weed is offline
Hold down the "N" key as you start Pro Tools...
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-25-2020, 12:02 PM
Thank you musicman691 and The Weed. I tried to do your proposes but I don't solved my problem. Excuse me, I'm not a professional and perhaps I'm wrong...
Old 01-28-2020, 10:10 PM
Cacov's Avatar
Cacov Cacov is offline
I don't think it has anything to do with Pro Tools version intalled, I get same alert everytime I plug and use the Pro Tools | Duet, but it works anyway.
I think on the last couple of recent updates of PT IO (Maestro2 in disguise)/driver/firmware combo, they forgot to bring that firmware check up to date. Maybe you could try and post this to the correspondent Duet/Quartet branch if you want to reach for help on specific hardware.
macOS High Sierra | Apogee Groove & Symphony I/O | Pro Tools 2019
Non-Avid Employee | Sound Engineer
Old 01-30-2020, 09:28 AM
Thanks, Cacov!
I will try!
Firmware Problems with my ProTools Duet Menkee Pro Tools | Duet & Pro Tools | Quartet 1 01-10-2020 10:55 AM
Avid Pro Tools Duet not recognized by Firmware Updater or Pro Tools I/O Control Panel werner44 Pro Tools | Duet & Pro Tools | Quartet 14 02-25-2019 04:02 PM
Pro Tools | Duet NEW Firmware v2.68 from AUG2018 Cacov Pro Tools | Duet & Pro Tools | Quartet 0 09-07-2018 10:50 AM
HELP: ProTools duet firmware updater does not detect Duet mikeserman Pro Tools | Duet & Pro Tools | Quartet 1 10-18-2015 03:12 PM
