Old 01-31-2019, 09:26 AM
Media Man Media Man is offline
Default Pro Tools version
I am working on a project that was recorded on older version of Pro Tools, and I get that message when opening it, as well as all of the output and bus warnings.
Is there a way to tell which version of Pro Tools it was last saved on?
Also, the outputs and buses are all wacked from the originating session, and MY outputs and buses are not appearing in the drop down menu. Any way to get mine to appear in that menu?
Media Man
Old 01-31-2019, 08:25 PM
Default Re: Pro Tools version
Tough to say what version they were done on, but the file extension might narrow it down a bit(.pts, .ptf or .ptx). If you are able to get the session(s) to actually open, the IO problem isn't too bad to deal with(but you will need to repeat for each session and Save As(update the name) so they open with your IO in the future. To fix the IO, open a session and do to Setup>IO and click the Bus tab. Select and delete all the paths, then hit the DEFAULT button(or IMPORT your settings). Then click the INPUT tab and do the same, and then the Output tab and repeat. The idea is to remove all paths that don't match your system and then Save As and name it as you see fit.
If you still have issues, let us know what version of PT that you are running, and check those file extensions on the PT session icon(not the folder)
Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0 Danishan90 macOS 10 02-10-2014 03:11 AM
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but Patrick H macOS 3 11-20-2012 02:46 PM
OMF version 1.x. Pro tools only supports OMF version 2.x SoundLogicAudio Post - Surround - Video 6 02-20-2009 12:40 AM
This version of Pro Tools requires DAE version 5.1 or later. Josh Jagdfeld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-09-2007 03:31 PM
I guess an XP version of Pro Tools will be here before we get an OSX version... ckerian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-11-2002 05:58 AM
