Old 01-14-2001, 06:15 PM
Gulliver Gulliver is offline
Default Re: New Hard Drive
I have the 30GB Western Digital, works great. Both of the above have 2MB cache, both have around 9ms access time. I would go with the one with the lowest price; which will probably be Western Digital.
Old 01-14-2001, 07:17 PM
slinky slinky is offline
hell no....don't ever get a maxtor or western analog...IBM or seagate always.
Old 01-15-2001, 12:00 AM
Axeslinger Axeslinger is offline
Default New Hard Drive
Im gonna buy my second HD for my G4 (audio dedicated drive)....im looking at either a maxtor or western digital 40 gig 7200 rpm...any suggestions as to which one and experiences youve had with both brands?? thanks!
Old 01-15-2001, 09:47 AM
David Johansen David Johansen is offline
Dont get a maxtor or a western . I ´v heard people got a lot of trouble using these on Mac´s . They work on pc .
Get a IBM nothing else !!!!!
Old 01-15-2001, 09:58 AM
lwilliam lwilliam is offline
Well, I guess different people, different experiences...
I have a Maxtor 28GB drive which has worked flawlessly for over a year.
LW
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Old 01-15-2001, 10:32 AM
evandaum evandaum is offline
I have 2 Maxtor 40GBs that have served me well. I have had several very bad experiences with Western Digital drives though, so I'd stay clear of them if possible. IBMs are great, and you get what you pay for with Seagate.
-Evan
Old 01-15-2001, 04:40 PM
Western Digital doesn't work well with Macs? My G4 came with a stock Western Digital.
Seagates are nice, but check the buffer size before ordering. My Western has 2MB cache. The Seagate only had 512K, and was a lot more money.
Statistically, there were reports that showed IDE drives being more reliable than SCSI. This is in part because of the huge quantity produced, the percentage of failure is slightly less. If your drive works for the first week, there is a very small chance of problems in the future; no matter which one you choose.
Old 01-15-2001, 04:45 PM
Thanks for the help guys but unfortunately my plans will be on delay currently ...my dual 450 g4 seems to have the power switch problem that was real common a few months back and it doesnt even start up at all!! I took it to my closest service center for repair...hopefully i will have it back soon
Old 01-15-2001, 06:42 PM
mustafatron mustafatron is offline
the cache size of a hard drive does not matter at all for daw use. go for the most data throughput ata 100's. ibm and seagate are great hard drives, when it comes down to it with eide just go for the most gigs you can get for the money..
Old 01-15-2001, 09:00 PM
The current Apple G4s are only ATA 66. Getting ATA 100 will not make a difference. Throughput doesn't matter either. On an ATTO card, it is actually required to lower the sync and burst rate to slow down the drives.
The important thing is access time, as the drive needs to grab a little bit of each audio file as the recording streams. Most IDE drives are about 9ms. Seagates are a litle less, but I think they just push their claims.
As far as a memory buffer, I think it is best to get a fair amount. SCSI A/V drives are the same as regular SCSI drives except that they have more memory. I believe this helps for a steady stream in the event of OS inefficiency.
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Valid Audio Drive (hard drive issue) MacPro / HD3 owenpop Pro Tools TDM Systems (Mac) 5 01-11-2008 12:28 PM
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
Hard Drive Performance Dual Processors and Dedicated Audio Drive j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-03-2000 05:52 PM
