Old 07-02-2014, 03:49 PM
kkfaudio kkfaudio is offline
Default Video Ref questions
Hello all...
In an effort to get the best sync we can, I've recently added a Kona 3G video card (replacing BM intensity pro) and will be taking delivery of a SyncHD shortly.
I'm trying to get my head around the "Video REF" connections and the "Loop Sync" connections on the Sync HD and HD Omni, and "REF Loop" on the Kona.
What's the proper way to link everything up? Do I send the Tri Level house sync to the Sync HD --> Omni Word Clock --> Kona breakout box REF Loop and terminate it? Or is another order preferable? Do I still use the loop sync to go from Sync HD to Omni and back?
Slightly confusing to me, as none of the connections are labelled the same from box to box.
I hope I've given enough info - but I'll be happy to add more if necessary.
Thanks!
Kevin
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 07-02-2014, 04:04 PM
Craig F Craig F is offline
Default Re: Video Ref questions
House Tri-Level to both the Sync HD and the Kona (Kona, REF Loop is a loop through if you don't have more than source port from House Sync)
Loop Sync: out of the Sync HD to Omni Loop in > Omni Loop out to Sync HD Loop in
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 07-02-2014, 04:36 PM
Excellent, Craig.
Thanks for the quick reply!
Kevin
Kevin Ferrier
Old 07-03-2014, 10:16 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
As Craig said.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2020.3 Ultimate ● macOS High Sierra 10.13.6
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 03-27-2015, 05:41 PM
fsrenduro fsrenduro is offline
Reviving an old thread. I'm doing an Aja IO xt, Aja Gen10 HD/SD Sync generator, Sync HD and an Omni.
The Gen10 has 6 outputs that can send HD or SD signal and one labeled AES 11. In my situation would I do outputs 1 & 2 (set for HD) going to Vid Ref In on the Sync HD or is it going to Word Clock In?
On the Aja IO xt does it go to LTC In/Ref In?
Tell me if I'm understanding this right. The Gen10 feeds both the Sync HD and IO xt as described in the above quoted post. The Sync HD then loops out to the Omni and the Omni back to the Sync HD.
With the IO xt getting fed by the Gen10 only it then does HDMI out to my monitor.
Hope this makes sense. Please advise as if you were talking to a 12 year old
Mac Pro Quad Core 3.7
32 gigs RAM
Native Thunderbolt & Omni
OS 10.9.2
PT 10.3.10 HD
PT 11.3.1 HD
PT 12.1 HD
Old 03-27-2015, 06:55 PM
Chief Technician's Avatar
Post Re: Video Ref questions
Aja Gen10 Output 1-->Sync HD video ref input
Aja Gen10 Output 2-->Aja IO xt video ref input
Put a 75Ω terminator on the Sync HD video ref loop output
Sync HD Loop Sync Output-->Omni Loop Sync Input
Omini Loop Sync Output-->Sync HD Loop Sync Input
Old 03-27-2015, 10:49 PM
Thank you very much. Very concise and clear.
32 gigs RAM
OS 10.9.2
PT 10.3.10 HD
PT 11.3.1 HD
PT 12.1 HD
Old 05-13-2016, 12:29 AM
Dingo90 Dingo90 is offline
I have the same set up, but am having trouble setting up my sync hd settings in my session setup.
I selected SYNC HD as my clock source
and in sync setup
clock ref: internal/VSO
positional ref: LTC
video ref format: NTSC
does that look right?
thanks
Old 05-13-2016, 08:52 AM
and in sync setup
positional ref: LTC
thanks
Keep Sync HD as your clock source but select Video Ref instead of Internal/VSO under Clock Ref. Then under Video Ref Format you should have a number of resolutions and frame rate options. Select the one that matches your project or Gen10 settings.
Scott Gatteño
Yessian
Old 05-13-2016, 01:58 PM
great, thanks Scott!
HTML code is On
new guy video questions tracktensionrecords Post - Surround - Video 5 05-30-2008 07:42 PM
A few questions on video Craig F Post - Surround - Video 0 06-10-2005 11:03 AM
video/audio questions grateful General Discussion 1 02-28-2004 06:17 PM
firewire video - still more questions Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-06-2002 11:02 PM
Questions after the video Curtisguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-14-1999 09:36 PM
