Old 01-28-2011, 01:57 PM
Dingo90 Dingo90 is offline
Default can this be done? (renumbering bars within sub beats)
I can only find ways to renumber my bars on the beat, but not in between sub beats.
If for some reason I want to change my current session's bar 9, beat 2 sub beat 142 as the session's new Bar 1, beat 1, can this be done?
Old 01-28-2011, 04:59 PM
BaileyBass BaileyBass is offline
Default Re: can this be done? (renumbering bars within sub beats)
If I understand your question, yes it can be done.
1. Change all tracks to sample based (not tick).
2. put the cursor exactly where you want the new Bar 1.
3. Command-i
4. In the dialog for bar number type in 1
5. Hit enter.. and song start will change to there.
6. change all the tracks that you changed from Tick to Samples back.
(If you do not change tick based tracks to samples, those regions will move with the new location) SB
Old 01-28-2011, 06:32 PM
slater05 slater05 is offline
That should work. But you could also go to Event -> Time operations -> Move song start, but I'm not sure it it lets you get specific enough for sub beats
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 01-28-2011, 06:34 PM
Exactly...Unfortunately that route "rounds" it to the nearest bar... That would be possible if one used "insert time" to move the beginning of the session over enough so the sub-beat point that the OP wanted to renumber fell on the beginning of a bar.
Old 01-28-2011, 10:34 PM
Hey, Mike,
this worked, thanks!
Old 01-29-2011, 07:10 AM
Hey, Mike,
Just curious, but did it move your start "close" to where you wanted it, or exactly? If you look closely using undo/redo you might see it. Were you given a Bars/Beats/Subdivision option in that dialogue?
I was going from memory in my suggestion above, but maybe PT9 now has that "sub bar" functionality. ( it definitely did not before) That would be great. SB
Old 01-29-2011, 12:09 PM
hey, Bailey,
it moved the start exactly where I need within the sub beat.
Old 01-29-2011, 12:35 PM
hey, Bailey,
Great. I think you got lucky. PT9 still only allows for a "bar" resolution using that window, and evidently the bar fell right where you need it. For very specific renaming of Song start, the only way I have found to land in sub-beats is the method I described. I tested on my PT9 rig, all is as I thought. sb
Old 01-29-2011, 02:04 PM
yes, but all I had to do was switch to timecode as timebase in that window and then enter the exact timecode and viola!
Old 01-29-2011, 08:33 PM
You cheeky monkey haha that's clever
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
[IMG] code is Off
Renumber bars okay but what about renumbering minutes marks ? montreal macOS 13 10-19-2013 03:30 PM
Renumber bars okay but what about renumbering minutes marks ? montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-17-2013 10:45 AM
Bars and Beats GTTTT Pro Tools 10 4 04-05-2013 04:51 AM
Is it possible to zero out Bars and Beats? jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-23-2004 09:55 AM
bars and beats.....its off Mikchek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-03-2003 01:47 PM
