#21
Re: Eucon 20.5 Automation Lag
We are working on this but not everyone is seeing it and its hard to repro. There are just 3 people on this thread out of thousands for instance. We are planning a bug fix release in a week or two and this has to be fixed in it.
#22
Thank you for addressing this. Would a a copy of my session help? I’d be happy to send it along to you.
Carlos Sanches Re-Recording Mixer Audio Circus Warner Bros. Animation http://www.imdb.com/name/nm0760851/ |
#23
same here
- automation lag - starting to write 4 secs after playback start (funny, the same "solution" - touching fader before pressing play works) - delayed layout switching, sometimes even like 10 seconds waiting for layout to change conf: mac os 10.14.4 eucon 20.5.0.149 protools 2020.3.0 avid s3 + avid dock + avid control (new version) on hyuawei tablet |
#24
Please elaborate? Did I miss this earlier?
#25
#26
how do you roll back? I don't believe that I have the installers for older versions of Eucon and I'm not seeing those in my account. Also how would I roll back the ipad app. Would it work even though I updated the dock firmware?
#27
#28
Eddie,
This doesn’t work. I call it Priming the fader. You can place your finger on the fader while the transport is stopped and when you press play, the red line will show as if you’re writing automation but fader movements will not register for 2-4 seconds. The other way way is pressing play first and immediately touching the fader (.5 sec) but the fader does not register touch for 2-4 seconds. Interestingly enough, for me, if I time the touch fader to just about 1 second, then automation writes as expected. |
#29
Android: https://www.tripplite.com/usb-c-to-g...ing~U43606NGBC iPad: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I run everything into an unmanaged switch and have the computer serve DHCP - android tablets seem to have trouble otherwise. |
#30
Can I confirm this. If you grab the fader straight away you get the delay, but if you wait a second it starts writing OK ?
2018.7 Automation choppy with Eucon controller | SFXgeek | Artist Series | 11 | 03-18-2021 09:06 AM |
Logic 10.4.2 breaks Eucon automation modes. | robertg | Artist Series | 25 | 05-19-2019 04:59 PM |
Eucon/Artist Mix Trim Automation selection | HotRats_Reloded | Artist Series | 1 | 10-06-2018 05:29 AM |
automation mode glitch almost fixed in Eucon 3.4 ??? | yoerik | Avid S1, S3, Dock and Control App | 7 | 09-05-2016 07:15 AM |
PTHD 12.1 and EuCon automation | reichman | Artist Series | 1 | 07-09-2015 10:45 AM |
