running Logic Audio and Pro Tools at same time
Hi out there! Maybe you know this thing:
I'd like to use Logic Audio as my MIDI Sequencer and PT as Audio Sequencer at the same time. The sense: I can control my MIDI Devices (such as Synths, Sampler,...) through Logic (better MIDI Implementation) and record their Outputs with Pro Tools (better Audio performance). So I need all my MIDI Ports in Logic (with disabled Audio driver). I tried to launch first Logic without Audio drivers installed, but PT doesn't launch ("hardware is in use by another application..."), then I tried to launch PT first, but then I got no MIDI Ports in Logic. Do I really need another for running both programs at the same time? help needed Bernie |
Re: running Logic Audio and Pro Tools at same time
nobody got an answer???
You need to disable your MIDI and Wav drivers for the 001. It's in the control panel/ Multimedia/ audio options. If this isn't clear enough do a search and you'll find about 1000 of these same responses.
Mike Blanchard Engineer |
Anyone Tried Running PT9 & Logic At The Same Time - Synced? | Sonic Nomad | Pro Tools 9 | 6 | 11-10-2010 12:05 AM |
running PTLE and LOGIC at the same time | weighbor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-29-2010 06:36 AM |
Running Pro Tools and Logic? | Jsalam112 | Pro Tools TDM Systems (Mac) | 2 | 01-15-2005 08:33 PM |
Running Logic & PT At The Same Time??? | naman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-01-2001 02:29 AM |
Running Pro Tools through Logic? | NiklasP | Tips & Tricks | 1 | 10-09-2000 06:07 PM |
