Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 04-10-2019, 06:49 AM
JingleDjango JingleDjango is offline
Default PT 2018.12 Crashes When Attempting Bounce to Disk
As of this morning, every time I try to 'Bounce to Disk' on certain sessions, PT crashes out. I can't think of anything that's changed about my system that would cause this.
-These are mix sessions that were begun at home on a PT2018.12 Standard system. No issues with BTD then.
-I brought them to the studio to finish the mix. PT2018.12 HD Native system there.
-I have them back at the home studio and I want to bounce a mix revision but PT keeps crashing out when I select Bounce to Disk. The bounce dialog doesn't even make it on-screen before the crash report dialog.
Any suggestions? I've tried a system reboot and trashing the preferences.
Old 04-10-2019, 06:57 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: PT 2018.12 Crashes When Attempting Bounce to Disk
Possible plugin mismatch. Try without plugins and if that works gradually add to find culprit(s) and print those before bouncing.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 04-10-2019, 12:43 PM
Thanks for your response.
I just tried again with all inserts and sends disabled and got the same crash out.
Can any useful information be gleaned from the crash log?
Old 04-10-2019, 04:15 PM
64GTOBOY's Avatar
I dont know about the crash log, if you have a current support plan you can start a case with avid. Have you tried doing a save as and/or save copy then BTD from the copy or save as?
Old 04-11-2019, 11:11 PM
spock999 spock999 is offline
move your PT pref to anothe folder and try it again. You can also try to re import your i/o
Your eyes can deceive you don't trust them , Mix with your ears
Bounce to disk offline error on 2018.4! take care, use online instead! tamtamstudio Pro Tools 2018 25 08-19-2018 03:36 PM
Assertion error when attempting bounce to disk BruceB Pro Tools 9 0 02-22-2017 06:21 PM
ProTools 9.0.3 HD Crashes after Bounce To Disk Syncronix macOS 3 06-16-2011 06:20 PM
Bounce To Disk now Crashes my system ?? David Lawler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-23-2001 06:14 PM
bounce to disk crashes John Imholz Pro Tools TDM Systems (Mac) 2 01-23-2000 01:18 AM
