Old 02-27-2016, 08:42 AM
simonyeah simonyeah is online now
Default Drag clips from severals tracks to one same tracks
Hello
Say I have clips spread on different tracks and I want to regroup them on the same track.
Is there a way to do that in a faster than dragging all individual clip separately ?
Many thanks
Simon
Old 02-27-2016, 01:09 PM
minister's Avatar
minister minister is offline
Default Re: Drag clips from severals tracks to one same tracks
Sure. Create a new track. Open the Bin Window, Select all your clips on your old track, then drag the selection from the bin.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 02-27-2016, 01:28 PM
jeffro's Avatar
jeffro jeffro is offline
...and make sure you set Timeline Drop Order to Left to Right before dragging them from the bin.
File Type: png Screen Shot 2016-02-27 at 12.27.20 PM.png (67.4 KB, 0 views)
Old 02-27-2016, 03:33 PM
Thanks but I want the clips to be at the same position in the timeline that they were in the previous tracks. The trick with the bin does not preserve the position of the clips in the timeline ?
Old 03-01-2016, 06:20 AM
So not possible ?
Old 03-01-2016, 06:30 AM
Drew Mazurek's Avatar
Clip Groups.
www.drewmazurek.com
Old 03-01-2016, 06:42 AM
dieffe dieffe is offline
If I understand correctly what you're trying to do, try this:
- select the Object Grabber tool
- select all the regions in the first track, Control drag to move to the comp track.
- select all the regions in the second track, Control drag to move to the comp track.
- repeat until you moved all the regions
Old 03-01-2016, 08:54 AM
This.
I misunderstood what the OP wanted but I see now and this is the right answer.
www.drewmazurek.com
Old 03-01-2016, 09:14 AM
Yes this is what I want to achieve move all clips on one comp tracks.
I don't understand how you do it with clips group Drew. Can you elaborate ? Many thanks
Old 03-01-2016, 09:15 AM
I misunderstood and therefore ignore my post.
www.drewmazurek.com
HTML code is On
Can't 'Drag across multiple tracks' mrhappy1997 Pro Tools TDM Systems (Mac) 1 11-11-2015 05:49 PM
Consolidating Clips/tracks Tampaguitar Pro Tools 11 9 12-20-2013 12:33 PM
HELP! - Can't drag tracks to pro tools Tha Yungsta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-07-2008 12:31 AM
Drag Copy CD Tracks seems broke Mark Wheaton Pro Tools TDM Systems (Mac) 2 08-31-2006 02:23 PM
Removal of Clips & Pops on Tracks? pribb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-29-2004 03:10 PM
