Old 10-05-2015, 03:37 PM
bernhard bernhard is offline
Default Re: 12.2.1 Automation Improvements
Wasn't there an issue where the automation would be overwritten for the entire timeline and it wouldn't undo? I remember going back to Session Backups at one point. Maybe I'm confusing issues.
No, it was always undoable, but usually you dind't notice before your 32steps of UNDO were gone.
Old 10-05-2015, 04:05 PM
smurfyou smurfyou is offline
That sounds like something I would do. An undo history list would be nice.
~Will
Old 10-06-2015, 03:01 AM
You mean like the one under windows/undo history? It shows all your 64 undo steps and you can set if it includes automation moves or not.
PTHDn 2019.10 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 10-06-2015, 08:36 AM
Haha I honestly forgot about that window, I never have it open. I have a few window configs I switch between, maybe I should find a space for it.
Thanks for the wake up
Back to the OP, I liked "Guardian Angel". I wasn't aware it was compatible with 11.
~Will
Old 10-06-2015, 10:58 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
I think we should all campaign for Frank's eminently sensible suggestions of logic and not accept this conservative band aid of a solution.
Sorry Avid, but it really shows you are not agile enough. If you make a mistake, hold your hand up and correct it, stop getting bogged down in committees.
Do you think we like the preference section? You are getting there with the IO section and have shown some innovation and "software remorse", do the same with the automation! Listen to your customers and get some agility back. it's what makes modern companies work!
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
  #16
Old 10-06-2015, 11:20 AM
mesaone mesaone is offline
Mike and others, maybe you would find my IdeaScale suggestion worth supporting. I think it could be a much nicer method of managing automation events. http://protools.ideascale.com/a/dtd/...st/204061-3779
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
  #17
Old 10-07-2015, 05:43 AM
made made is offline
did anyone actually try this new "feature"/fix?
I installed 12.2.1 and everything is the same as always... no selection before playback - automation is written to entire session.
couldn't find a preference setting or anything.
so if this new thing didn't actually make it into this version, maybe change the functionality - as Frank mentioned earlier ( and probably the last 10 years) - to "Write to Selection" as it says on the button.
to prevent a "**** storm" from users that use the previous behaviour everyday, add a function that writes the entire session while holding the option key or something similar.
Thanks!
i7 3,39GHz, 32GB, PTHD2018.12, OS 10.12.6, S3, Transport, (EuCon 19.5.1.44)
LIO
AJA XT-Express
Reaper 5.97, Fireface UCX
MacbookPro i7 PTHD2018.12 10.12.6
  #18
Old 10-07-2015, 06:18 AM
Ultimately I'd like this to be implemented:
http://protools.ideascale.com/a/dtd/...ng/118092-3779
Would improve and fix a lot of issues on the same ticket.
f.
  #19
Old 10-07-2015, 06:24 AM
Thanks!
I think the way they made it (can't check. Don't have 12) is that you only get warned when you made a selection while playing and then hitting write to selection while still playing. They did this to keep the write to all feature when no selection is made in stop.
Not bad not but not great either since it assumes that the write to all thing is done intentionally all the time which is isn't.
In my case I'd say I use that as a feature in 0.000000000001% of all clicks on the write to button.
  #20
Old 10-07-2015, 08:28 AM
+ a lot
cheers
BAFTA member
IPS member
HTML code is On
Improvements fsb1 Artist Series 0 09-25-2010 09:15 AM
Rtas improvements in PT 8? grandcoolee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-17-2008 11:15 AM
Pro tools needs some Improvements Xbuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-19-2005 05:52 PM
Possible improvements to the DUC? AVGuru1 General Discussion 0 01-21-2005 01:20 PM
Digi001 NEEDS IMPROVEMENTS! mixermon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 42 10-25-2001 01:51 AM
