Old 10-24-2013, 07:11 PM
lpfan799 lpfan799 is offline
Default 002 not recognized
Always used 002 with PT8 LE mac setup. Recently got windows 7 PT10 HD setup. Got 192 (both digi and analog) hooked up, but when i load PT the 002 is now not recognized. Upon re-trying mac setup it works immediately (not cable or 002). Windows setup after loading, 1394 light not coming on, nor is it in peripherals or I/O setup. Downloaded and installed latest drivers but that didnt fix it. Any suggestions? Thanks in advance
Old 10-24-2013, 08:38 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: 002 not recognized
Hi, Does the 002 show up in Device Manager? Have you tried any alternate firewire drivers?
Help us Help You - READ THIS Before Posting!
Chris
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.10
Old 10-25-2013, 04:05 PM
if it does show up in device manager, what would it be called. (doesnt show up as digi,avid, or 002). Also just updated firewire drivers and that didnt fix it.
Old 10-25-2013, 05:10 PM
attempting to re-install PT right now
Old 10-25-2013, 09:13 PM
re-install didnt fix it, can anyone confirm they got a 002 running on a windows 7 64 bit system. some forums are telling me it hates win 7
Old 10-25-2013, 10:37 PM
cwsand's Avatar
Not sure, I had an 003 Rack+ for a while, don't remember exactly how it was named in Device Manager. Should be pretty obvious though - it will be under "Sound, video and game controllers".
Actually you need to try the alternate firewire drivers, like the Legacy ones. The process is listed here: http://avid.force.com/pkb/articles/en_US/troubleshooting/en349411?popup=true#enable_legacy
Have you done all the optimizations and troubleshooting listed here?
A lot of people use 002's with Windows 7, but you need to make sure your pc sees yours in Device Manager first.
It would be helpful to know (lots) more about your computer so definitely post a SANDRA.
Chris
Help Us Help You
Chris
PreSonus Digimax LT
Old 10-26-2013, 12:17 AM
Ok so first i will get it working in my device managers - not sure what a sandra is but if it was explained i can def post that - thanks for the responses guys - once its solved i will def post the explanation of what worked to get it going
Old 10-26-2013, 09:35 AM
sw rec sw rec is offline
Be aware that for WINDOWS, the drivers for the 002/003 consoles (9.0.5) are not the same as the drivers for the racks (9.0.7). Accidentally using the wrong drivers opens a whole intriguing can of worms. (Ask me how I know...d'oh!!!)
BTW, I did in fact run an 002 Console on Win 7-64 Ultimate with PT10. (DID. I horse-traded my way into an 003, which works fine on 11)
Old 10-26-2013, 11:40 AM
cwsand's Avatar
Help Us Help You
Chris
PreSonus Digimax LT
USB mic not recognized epianoqueen macOS 15 05-30-2013 06:30 PM
003 now not recognized? dreamslide720 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-22-2011 05:31 PM
002 not being recognized honeyboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-04-2007 11:18 PM
002 Not Recognized, please help noisebrigade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-24-2007 10:48 PM
002 Not recognized? Earl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-26-2006 08:28 PM
