Old 06-26-2006, 01:06 PM
gsnaudio gsnaudio is offline
Default AVID SCSI Drive Permissions Issues
I am running an HD system (Pro Tools 6.9.3) on an Dual 2.7 GHz PowerPC G5 (Tiger 10.4.2) and I am unable to change the Ownership & Permissions on two AVID SCSI Drives. The 'Ignore ownership on this volume' is not available on the AVID SCSI Drives, where it is on all other drives. Also, when I go to Disk Utility and get info within Disk Utility the drive has 'Can Turn Owners Off :' set to No, where as the other drives are set to Yes - this option is not changeable.
Any thoughts on this?
Thank you
Old 06-26-2006, 09:24 PM
DigiTechSupt's Avatar
Default Re: AVID SCSI Drive Permissions Issues
In the Apple Disk Utility (in the "erase" tab), what does it say the drive's format is? I'm guessing it's a PC initialized drive.
If that is the case, you should be able to copy the data off of them onto your Mac, but they probably won't work too well as record/playback volumes for Pro Tools.
You would need to re-initialize the drive in the Mac Disk Utility as a "Mac OS Extended (Journaled)" drive.
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
Old 06-26-2006, 10:14 PM
Thank you for the info! Currently the two drives in the Avid removable chasis, the ones that I am concerned about, are my record drives. They seem to work fine but I am unable to share them. I will check into your thoughts when I am back in on Wednesday and see what I find. The system may have been installed, reusing the drives from the original os9.2 ProTools 5.1 system.
Thanks!
HTML code is On
Avid Media Drives - SCSI to USB, Plus Drive Servicing Mix Design Digidesign Hardware & Software 1 06-24-2013 08:23 PM
Avid Media Drives - SCSI to USB, Plus Drive Servicing Mix Design Storage Subsystems 1 06-22-2013 09:18 PM
Need help with permissions on external drive SteveGarman Pro Tools TDM Systems (Mac) 3 01-27-2012 12:42 PM
Slightly OT: Scary drive lockouts and permissions thermisonic Post - Surround - Video 5 10-23-2009 02:07 AM
Repair Permissions - Actual Hard Drive or Name? cheekypaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2004 11:03 AM
