Old 06-21-2000, 11:26 AM
Samhein Samhein is offline
Default QT4.1 + G4 AGP + OS 9 + MiroMotion DC30plus
Does this work?
Old 06-21-2000, 12:39 PM
vico vico is offline
Default Re: QT4.1 + G4 AGP + OS 9 + MiroMotion DC30plus
i don't know exactly, G4/350 pci graphics, QT4.0x+MacOS 9.0+dc30+ works, i did try QT4.1x and run into sync problems, went back to QT4.0x
regards
vico
mambo
Old 06-21-2000, 12:47 PM
What version of Premiere and MiroMotion extensions do you use?
Old 06-21-2000, 03:22 PM
hello,`
Premiere 5.1, miroMotion 1.2.1.
regards.
vico
mambo
Old 06-22-2000, 01:31 AM
Polaris Polaris is offline
Yes. We have G4/400/AGP+OS 9+QT4.1+Miro DC30plus+Miro 2.0b5 (beta) drivers+Premier 4.2.1 (needed for reconforming movies, 5.1 lacks this function). Seems to work fine. We do have an annoying problem with white dot grid over movie image but also happen on 9600+QT 3.02+OS 8.6 so I believe its unrelated. Good luck!
Polaris
Old 06-22-2000, 02:49 AM
Thanks for the input guys!
But the DC30Plus package we purchased came with Premiere 5.1.
We'll surely need the conforming feature. Why the hell did Adobe remove it?
Is there a workaround? Or do I have to go and buy a 4.21 version? Thanks
Old 06-22-2000, 10:32 AM
samhein,
use interpret footage, it's equivalent, also be very aware of the settings (or settings file) you use for capturing.
regards
vico
mambo
Old 06-22-2000, 11:23 AM
Thanks for the input!
Old 06-22-2000, 12:43 PM
Mark Wheaton Mark Wheaton is offline
My biggest confusion in Premiere is always the multiple frame rate and time base settings in various parts of the Movie Capture settings dialogs. It seems you need to set several and some only give you time base not Drop frame etc. Can anyone clarify each of the Premiere settings for frame rate/time base and which matter and which don't (or are dupicates?)? perhaps someone could post a chart with the Premiere dialog settings for each of the typical capture modes for a ProTools project that they use: 30 Frame, 29.97 NDF, 29.97 DF etc?
P.S.
Is it different for different cards?
Miro DC30 not DC30plus COCO Post - Surround - Video 7 03-19-2004 10:23 PM
Miro DC30Plus and Quicksilver Mac R Korsakov Pro Tools TDM Systems (Mac) 1 08-07-2003 07:47 PM
what´s your datarate on a DC30plus? Frank Kruse Post - Surround - Video 2 01-08-2003 01:36 AM
DC30Plus w/ PT 5.1 Mills James Productions Pro Tools TDM Systems (Mac) 2 03-14-2001 12:41 PM
DC30plus on a sawtooth G4?? Rob Daly Pro Tools TDM Systems (Mac) 2 02-07-2000 12:30 PM
