Old 04-15-2004, 07:14 PM
cyberbat cyberbat is offline
Default BSOD on any basic operation in PT win srvr 2003
Hi, I'm getting a Blue Screen Of Death almost as soon as I start doing anything. PT LE will start up, but if I try a simple operation like closing PT's main window, or looking at the hardware dialog and then closing that, I get a BSOD and a stop error (BAD_POOL).
On a similar machine in the room, the digi002 works fine with PT LE.
My machine: P4 3GHz with hyper threading, 1GHz RAM, ASUS P4C800 motherboard, radeon 9200, digi002, PT LE 6.1.1, windows server 2003, lacie firewire card. Machine was completely reformatted, reinstalled today, so the build up of hidden nasty crud should be low. There is also a steinberg 2020 card in the machine, but I have tried pulling this out and this has made no difference.
Motherboard BIOS is up to date. There is a Promise RAID array running as well, again with latest drivers.
Old 04-15-2004, 07:29 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: BSOD on any basic operation in PT win srvr 2003
Mmmmm...Maybe you should be over in the TDM Forum? AFAIK PT LE is only qualified for Windows XP Home and Pro, not 2003 Server. AAMOF, I don't think any version of Pro Tools is qualified for Windows 2003 Server. Also for PT LE, it's recommended by Digidesign that you disable Hyperthreading and RAID is not supported.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 04-15-2004, 07:30 PM
clarkepr clarkepr is offline
As I remember, PT doesn't support RAID, and also I think that it's only been tested on WinXP Home and Pro. Also, I don't think that hyperthreading is supported yet. Those factors may be the cause.
Old 04-16-2004, 12:25 AM
Calvin Calvin is offline
nor does it support hyperthreading.
Calvin
Old 04-16-2004, 05:19 AM
Phil O'Keefe Phil O'Keefe is offline
Yup, turn off hyperthreading and do not use a RAID. And no promises on Win Server 2003... it is not currently a supported OS. Sorry.
Phil O'Keefe
Some Basic & not so Basic Copyright Info everone should know. DrFord General Discussion 3 11-07-2010 05:49 PM
...some basic questions needing basic answers aponceenrile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2010 11:48 AM
[D-COMMAND] HELP#3 - Basic operation dsstudio ICON & C|24 1 01-30-2009 01:36 AM
New (2003) 1.25 G4 and old PT? spec space Pro Tools TDM Systems (Mac) 0 10-07-2003 08:22 PM
May 6, 2003 or may not Mancake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-07-2003 07:11 PM
