"too few samples" error
I have recently encountered a "this file has too few samples..." error when loading a session. The file PT is referring to had just been recorded by this very session. Any ideas as to what causes this condition?
Jay |
Re: "too few samples" error
The session file stores the info about the audio file sizes and region definitions. If you were to trim a parent file outside Pro Tools, then open its' session again, it would detect that that file "had too few samples". It is trying to tell you the name may be correct, but the file size is different. So far, when this has happened to me, Pro Tools was correct in telling me that the file was not the right one. Are you using 5.1.1?
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
Error 7053, "Wm exception". "TDM ProcessTypeGlues"(!) and SoundToys greyed out ! | LSNY | macOS | 1 | 02-08-2011 04:16 PM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
"No More Samples Available" Error (SSC 3.1) | fathermac101 | Digidesign Hardware & Software | 1 | 10-15-2002 12:03 AM |
