Command Click on MacBookPro does not do Right Click.
hi all
Command Click on MacBookPro does not do Right Click inside ProTools 2018-4. (on the track pad) It should.... I have checked preferences everywhere - can't find a solution. any ideas? thanks. |
Re: Command Click on MacBookPro does not do Right Click.
Another way: Mac Preferences > Trackpad > Secondary Click set to two fingers....or whatever you prefer and use that.
Have you tried trashing prefs? Mmm I'm seeing the same thing here, but I normally use a two button mouse with Pro Tools on my MBP so would not know if it normally works. |
I have noticed this consistently with various versions of ProTools.... so i know it isn't a PT prefs issue... doing more mobile work now (meaning.... doing some) so i would love to be able to do this with a modifier key. If you are seeing the same thing there.... maybe it just doesnt work? sooooo odd. thanks. |
this just in - a smart pal of mine said "It’s control click for right click. Not command click. "
Just bear in mind, although most manufacturers use ctrl click as a keyboard alternative for right click it is not 'hard wired' and you will find software where ctrl click just doesn't do the same thing as right click.
I used to be a 'die hard modifier key' user too, but I can assure you that once you're used to the two finger click on the trackpad it is faster and easier than ctrl click. And the good thing is, it will always mimic right click, while ctrl click doesn't do that in all apps. Happy clicking, Daniel |
best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Command+Right Click Quick Key Plugin Automation in PT 11 | Andrew814 | Pro Tools 11 | 1 | 03-11-2015 06:12 PM |
Avid can you please sort out the click track & Click 2 plugin | protoolsuserman | Pro Tools 11 | 14 | 11-14-2013 08:11 AM |
the Shift+Alt+Pom+click command | groovbro | Pro Tools TDM Systems (Mac) | 3 | 10-26-2008 06:45 PM |
Power Harness, click click click | director | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-14-2004 09:50 PM |
command click on volume | LL Lush | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-22-2004 01:00 PM |
